[OpenLayers-Users] BBOX Update Bug
GordonHo llian at gmx.net
Fri Nov 14 20:14:06 EST 2008
hi tim,
i'd be glad to supply any information i can.
i've seen no thrown error so far, as for the protocol its text.
if i can provide any more information let me know - though i've to admit,
that im new to openlayers and not too familiar with it yet.
thanks alot, gordon
Tim Schaub wrote:
> Hey-
> GordonHo wrote:
>> hi,
>> i think the bbox has a small bug in the update handler.
>> if an update is issued, and the retrieved data set is empty, the previous
>> loaded data set is beeing displayed again after a zoom change.
>> if the returned dataset is not empty, everything works fine.
> At a glance, it looks to me like the merge callback should always get
> called (this is the responsibility of your protocol).  If merge is
> called, layer.destroyFeatures gets called (yes, this is a blunt merge).
> So, I'm guessing something is going wrong in the protocol.  Could be a
> parsing error.  If you are seeing any errors or have any more detail,
> please open a ticket and attach anything relevant that helps reproduce
> the problem (relevant detail would include at least the format and
> protocol that you are using and ideally an example).
> Thanks,
> Tim
>> with best regards and alot thanks for this framework, gordon
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/BBOX-Update-Bug-tp1500265p1500975.html
