[OpenLayers-Users] Antartica region problem
Andrew Bailey
andy at planetnomad.com
Thu Oct 2 11:22:16 EDT 2008
hello there,
apologies if i've posted this several times today, i seem to have some
problems with nabble.
I'm very much a geoserver/openlayers newbie but i've cobbled together a
basic map showing blue marble imagery of the antartic region. The
problem i have can be best described by the attached image - a radial
section from the pole is not being displayed followed by a rectangluar
section on the right hand side. The radial chunk missing i would have
thought relates to the extent of my coverage stored in geoserver but it
looks good - -180 to 180 on X and -48 to -90 on Y. I have no idea what
would be causing the straight rectangular gap in the image. Image here:
http://img220.imageshack.us/img220/5153/wmssb9.png
I would appreciate any pointers to fixing this. As i say, i've only been
using geoserver and openlayers for a day now. Before then i was happily
doing unprojected google map code so this is my first WMS trial.
WMS is in EPSG:4030 but openlayers is projecting in EPSG:3031. I've used
the bounds as described by nsdic.org: -12400000,-12400000,
12400000,12400000.
Here is the native SRS WKT from geoserver, if relevant:
* Native Spatial Reference System for Coverage: Generate Envelope after
setting the property.
Native SRS WKT: GEOGCS["Unknown datum based upon the WGS 84 ellipsoid",
DATUM["Not specified (based on WGS 84 ellipsoid)", SPHEROID["WGS 84",
6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6030"]], PRIMEM["Greenwich", 0.0,
AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST], AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4030"]]
My Openlayers script;
<script
src="http://localhost:8081/geoserver/openlayers/OpenLayers.js"
type="text/javascript">
</script>
<script defer="defer" type="text/javascript">
var map;
var untiled;
var tiled;
function setHTML(response) {
document.getElementById('nodelist').innerHTML =
response.responseText;
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;
OpenLayers.DOTS_PER_INCH = 25.4 / 0.28;
function init(){
var bounds = new OpenLayers.Bounds(
12400000,12400000
var options = {
controls: [],
maxExtent: bounds,
maxResolution: 25000,
projection: "EPSG:3031", //WGS 84 / Antarctic Polar
Stereographic
units: 'meters'
map = new OpenLayers.Map('map', options);
// setup tiled layer
tiled = new OpenLayers.Layer.WMS(
"QQ:Antarctica_Image - Tiled",
"http://localhost:8081/geoserver/wms",
width: '800',
styles: '',
height: '800',
layers: 'QQ:Antarctica_Image',
srs: 'EPSG:4030',
format: 'image/png',
tiled: 'true',
tilesOrigin : "-180,-90"
{buffer: 0}
// setup single tiled layer
untiled = new OpenLayers.Layer.WMS(
"QQ:Antarctica_Image - Untiled",
width: '800',
styles: '',
height: '800',
srs: 'EPSG:4030',
format: 'image/png'
{singleTile: true, ratio: 1}
map.addLayers([untiled, tiled]);
// setup controls and initial zooms
map.addControl(new OpenLayers.Control.PanZoomBar());
map.addControl(new OpenLayers.Control.Navigation());
map.addControl(new OpenLayers.Control.Scale($('scale')));
map.addControl(new
OpenLayers.Control.MousePosition({element: $('location')}));
map.addControl(new OpenLayers.Control.LayerSwitcher());
//map.addControl(new OpenLayers.Control.OverviewMap());
map.zoomToExtent(bounds);
// support GetFeatureInfo
map.events.register('click', map, function (e) {
"Loading... please wait...";
var url = map.layers[0].getFullRequestString(
request: "GetFeatureInfo",
EXCEPTIONS: "application/vnd.ogc.se_xml",
BBOX: map.getExtent().toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'text/html',
QUERY_LAYERS: map.layers[0].params.LAYERS,
FEATURE_COUNT: 50,
WIDTH: map.size.w,
HEIGHT: map.size.h
OpenLayers.loadURL(url, '', this, setHTML, setHTML);
OpenLayers.Event.stop(e);
</script>
