[OpenLayers-Users] Antartica region problem
Christopher Schmidt
crschmidt at metacarta.com
Thu Oct 2 13:20:02 EDT 2008
On Thu, Oct 02, 2008 at 04:22:16PM +0100, Andrew Bailey wrote:
> hello there,
> apologies if i've posted this several times today, i seem to have some
> problems with nabble.
> I'm very much a geoserver/openlayers newbie but i've cobbled together a
> basic map showing blue marble imagery of the antartic region. The
> problem i have can be best described by the attached image - a radial
> section from the pole is not being displayed followed by a rectangluar
> section on the right hand side. The radial chunk missing i would have
> thought relates to the extent of my coverage stored in geoserver but it
> looks good - -180 to 180 on X and -48 to -90 on Y. I have no idea what
> would be causing the straight rectangular gap in the image. Image here:
> http://img220.imageshack.us/img220/5153/wmssb9.png
> I would appreciate any pointers to fixing this. As i say, i've only been
> using geoserver and openlayers for a day now. Before then i was happily
> doing unprojected google map code so this is my first WMS trial.
http://trac.openlayers.org/wiki/TroubleshootingTips#Problemswithimagesbeingincorrect
I expect this is a GeoServer problem, and once you get the URL to an
image, you'll be able to get help as to why. (my first guess is that
you're taking a geographic image and trying to reproject it on the fly
to a polar projection, which seems like it could introduce these kinds
of problems, but I'm not sure.)
> WMS is in EPSG:4030 but openlayers is projecting in EPSG:3031. I've used
> the bounds as described by nsdic.org: -12400000,-12400000,
> 12400000,12400000.
> Here is the native SRS WKT from geoserver, if relevant:
> * Native Spatial Reference System for Coverage: Generate Envelope after
> setting the property.
> Native SRS WKT: GEOGCS["Unknown datum based upon the WGS 84 ellipsoid",
> DATUM["Not specified (based on WGS 84 ellipsoid)", SPHEROID["WGS 84",
> 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6030"]], PRIMEM["Greenwich", 0.0,
> AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295],
> AXIS["Geodetic longitude", EAST], AXIS["Geodetic latitude", NORTH],
> AUTHORITY["EPSG","4030"]]
> My Openlayers script;
> <script
> src="http://localhost:8081/geoserver/openlayers/OpenLayers.js"
> type="text/javascript">
> </script>
> <script defer="defer" type="text/javascript">
> var map;
> var untiled;
> var tiled;
> function setHTML(response) {
> document.getElementById('nodelist').innerHTML =
> response.responseText;
> OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;
> OpenLayers.DOTS_PER_INCH = 25.4 / 0.28;
> function init(){
> var bounds = new OpenLayers.Bounds(
> 12400000,12400000
> var options = {
> controls: [],
> maxExtent: bounds,
> maxResolution: 25000,
> projection: "EPSG:3031", //WGS 84 / Antarctic Polar
> Stereographic
> units: 'meters'
> map = new OpenLayers.Map('map', options);
> // setup tiled layer
> tiled = new OpenLayers.Layer.WMS(
> "QQ:Antarctica_Image - Tiled",
> "http://localhost:8081/geoserver/wms",
> width: '800',
> styles: '',
> height: '800',
> layers: 'QQ:Antarctica_Image',
> srs: 'EPSG:4030',
> format: 'image/png',
> tiled: 'true',
> tilesOrigin : "-180,-90"
> {buffer: 0}
> // setup single tiled layer
> untiled = new OpenLayers.Layer.WMS(
> "QQ:Antarctica_Image - Untiled",
> width: '800',
> styles: '',
> height: '800',
> srs: 'EPSG:4030',
> format: 'image/png'
> {singleTile: true, ratio: 1}
> map.addLayers([untiled, tiled]);
> // setup controls and initial zooms
> map.addControl(new OpenLayers.Control.PanZoomBar());
> map.addControl(new OpenLayers.Control.Navigation());
> map.addControl(new OpenLayers.Control.Scale($('scale')));
> map.addControl(new
> OpenLayers.Control.MousePosition({element: $('location')}));
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> //map.addControl(new OpenLayers.Control.OverviewMap());
> map.zoomToExtent(bounds);
> // support GetFeatureInfo
> map.events.register('click', map, function (e) {
> "Loading... please wait...";
> var url = map.layers[0].getFullRequestString(
> request: "GetFeatureInfo",
> EXCEPTIONS: "application/vnd.ogc.se_xml",
> BBOX: map.getExtent().toBBOX(),
> X: e.xy.x,
> Y: e.xy.y,
> INFO_FORMAT: 'text/html',
> QUERY_LAYERS: map.layers[0].params.LAYERS,
> FEATURE_COUNT: 50,
> WIDTH: map.size.w,
> HEIGHT: map.size.h
> OpenLayers.loadURL(url, '', this, setHTML, setHTML);
> OpenLayers.Event.stop(e);
> </script>
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
