[OpenLayers-Users] ASP.NET AJAX + Openlayers + IE6 Error
Christopher Schmidt
crschmidt at metacarta.com
Fri Oct 3 11:34:40 EDT 2008
On Fri, Oct 03, 2008 at 02:27:50PM +0800, ???? wrote:
> Does anybody have the experience of using Openlayers with Asp.Net Ajax.We have a such program, but when debugging it in IE6, a error "ASP.NET Ajax client-side framework failed to load." occured.
> When I remove the reference of the Openlayers JS(remove this line '<script src="lib/OpenLayers.js" type="text/javascript"'></script>),the error disappears.So I think the error is the result of the conflict between openlayers and Asp.Net Ajax framework.Does anybody have a solution about this?
What happens if you try to use a Single File build? (One is included in
OpenLayers REleases as penLayers.js in the top level directory.)
Regards,
Christopher Schmidt
MetaCarta
