[OpenLayers-Users] ASP.NET AJAX + Openlayers + IE6 Error
小粟
weimin_su at 126.com
Tue Oct 7 09:25:01 EDT 2008
Thanks for Christopher's replay. I have tryed to use a Single File build. This error strangely disappeared, but other error occured.
Why?
Weimin Su
----- Original Message -----
From: "Christopher Schmidt" <crschmidt at metacarta.com>
To: "????" <weimin_su at 126.com>
Cc: <users at openlayers.org>
Sent: Friday, October 03, 2008 11:34 PM
Subject: Re: [OpenLayers-Users] ASP.NET AJAX + Openlayers + IE6 Error
> On Fri, Oct 03, 2008 at 02:27:50PM +0800, ???? wrote:
>> Does anybody have the experience of using Openlayers with Asp.Net Ajax.We have a such program, but when debugging it in IE6, a error "ASP.NET Ajax client-side framework failed to load." occured.
>> When I remove the reference of the Openlayers JS(remove this line '<script src="lib/OpenLayers.js" type="text/javascript"'></script>),the error disappears.So I think the error is the result of the conflict between openlayers and Asp.Net Ajax framework.Does anybody have a solution about this?
> What happens if you try to use a Single File build? (One is included in
> OpenLayers REleases as penLayers.js in the top level directory.)
> Regards,
> Christopher Schmidt
> MetaCarta
