[OpenLayers-Users] How to add WMS Layer published by MapGuide
Zac Spitzer zac.spitzer at gmail.com
Wed Oct 8 07:57:41 EDT 2008
Paul,
Isn't that only required for dynamic layers, not WMS?
z
On Wed, Oct 8, 2008 at 10:54 PM, Paul Spencer <pagameba at gmail.com> wrote:
> Hi,
> this is happening because of the way that MapGuide works, it requires
> two calls to the server in some situations, specifically for
> overlays.  The first request is issued as an XMLHttpRequest and is
> governed by the same origin policy of browsers (it won't let you talk
> to a server from a different domain than the one the page was loaded
> from).  If your app is hosted on the same server as the mapguide web
> tier, then you should not be affected by this error.
> This won't help you now, but MapGuide OS is just about to change this
> behaviour to remove the need for the GETVISIBLEMAPEXTENT call for the
> imminent MapGuide OS 2.1 release that will probably come out towards
> the end of October and the MapGuide layer in OpenLayers will be
> updated to support this new behaviour (and remove the source of your
> problem) at the same time.  So hopefully by the time OpenLayers 2.8
> (or whatever the next version is) comes out, this will all be a non-
> issue anyway.
> Cheers
> Paul
> On 5-Oct-08, at 10:01 AM, carls wrote:
>> I need to access Mapguide OverLayer to Openlayers, but there are
>> something
>> wrong with it (access denied with XMLHttpRequest.open(......)).
>> So I moved to Add WMS Layer published by MapGuide. I tested many
>> times,
>> there is always a empty image displayed.
>> How to config the WMS Data/Layer published by MapGuide and how to
>> set the
>> access way to it?
>> Thanks!
>> View this message in context: http://n2.nabble.com/How-to-add-WMS-Layer-published-by-MapGuide-tp1298795p1298795.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
