[OpenLayers-Users] Problem adding a new property to a control
Eric Lemoine
eric.c2c at gmail.com
Wed Oct 8 15:51:55 EDT 2008
Hi
What does actually go wrong? What does FireBug tell you?
Eric
2008/10/8, Javier Galán <javiergalans at gmail.com>:
> Hi all
> I'm trying something simple but doesn't work. I want to add a new property
> to the scale control, for allow to choose between abbreviate or not the
> scale.
> What I did is:
> OpenLayers.Control.Scale = OpenLayers.Class(OpenLayers.Control, {
> * Property: abreviate
> * modificantion for abreviate or not the scale value
> * {Boolean}
> * default : false
> abbreviate: false,
> * Method: updateScale
> updateScale: function() {
> var scale = this.map.getScale();
> if (!scale) {
> return;
> if (this.abbreviate){
> if (scale >= 9500 && scale <= 950000) {
> scale = Math.round(scale / 1000) + "K";
> } else if (scale >= 950000) {
> scale = Math.round(scale / 1000000) + "M";
> } else {
> scale = Math.round(scale);
> }else{
> this.element.innerHTML = OpenLayers.i18n("scale", {'scaleDenom':scale});
> It works fine until I call the scale control with the property
> map.addControl(new OpenLayers.Control.Scale({'abbreviate':true}));
> Anybody colud sayme what I'm doing wrong.
> Thank's in advance
