[OpenLayers-Users] FW: Toggling layers without LayerSwitcher
Kimball, David (DCR)
David.Kimball at state.ma.us
Wed Oct 8 12:10:56 EDT 2008
Thanks Pierre! That worked great. My new code (called by HTML
radiobutton event) is:
function changeSymbolization(byField){
var byFieldSplit = byField.toString().split(',');
var usersChosenLayers =
map.getLayersByName(byFieldSplit[0]);
if (usersChosenLayers.length > 0)
{map.setBaseLayer(usersChosenLayers[0]);}
else {alert("Symbolization not found");}
if (byFieldSplit.length > 0)
{document.getElementById("theLegendTitle").innerHTML = byFieldSplit[1];}
document.getElementById("theLegend").src =
"http://giswebservices.massgis.state.ma.us/geoserver/wms?VERSION=1.1.0&R
EQUEST=GetLegendGraphic&LAYER=massgis:DCR.TOWNS_POLYM_FORESTRY&STYLE=DCR
.TOWNS_POLYM_FORESTRY::" + byFieldSplit[0] +
"&WIDTH=16&HEIGHT=16&FORMAT=image/png";
||||||| David Kimball
||||||| GIS Specialist
||||||| MA Department of Conservation and Recreation
||||||| http://www.mass.gov/dcr/stewardship/gis/
||||||| david.kimball at state.ma.us
||||||| 617.626.1447 phone
||||||| 617.626.1349 fax
-----Original Message-----
From: Pierre GIRAUD [mailto:bluecarto at gmail.com]
Sent: Tuesday, October 07, 2008 3:41 PM
To: Kimball, David (DCR)
Subject: Re: [OpenLayers-Users] FW: Toggling layers without
LayerSwitcher
Hum, I got too quick.
Of course setBaseLayer is to be called on the map object.
http://dev.openlayers.org/apidocs/files/OpenLayers/Map-js.html#OpenLayer
s.Map.setBaseLayer
On Tue, Oct 7, 2008 at 9:38 PM, Pierre GIRAUD <bluecarto at gmail.com>
wrote:
> I think you'd better try to call setBaseLayer instead of setVisibility
> on your layers.
> Regards,
> Pierre
> On Tue, Oct 7, 2008 at 4:00 PM, Kimball, David (DCR)
> <David.Kimball at state.ma.us> wrote:
>> Hi everyone, I looked into this a bit more and I have a little more
info
>> on what's happening (although I still haven't solved the problem).
>> If I create my map with both the layerswitcher control and my HTML
>> radiobuttons:
>> http://maps.massgis.state.ma.us/dcr/forestry11.html
>> it becomes clear that the HTML radiobuttons are making layers
>> visible/invisible, but the layerswitcher control is not updating to
>> match the chosen layer.
>> If I look at the requests being sent to the server using FireBug, it
>> becomes clear that clicking an HTML radiobutton other than the
>> default/top choice causes the correct request to be sent (i.e. the
>> correct Layer with the correct STYLES is requested and the
appropriate
>> image is returned and displayed). Then, when a pan or zoom operation
is
>> performed on the map, an incorrect request is sent, with the
>> top/original layer (with STYLE of
DCR.TOWNS_POLYM_FORESTRY::SUSTCOM_SC
>> for the main layer) being requested (probably because this is still
the
>> selected layer in the layerswitcher control?). An image is returned
>> from the server showing the top/original layer instead of the user's
>> selected layer, and the map does not get refreshed (probably because
the
>> top layer, in the returned image, is set to invisible).
>> A few clarifications:
>> 1) I want to have radiobuttons that are outside the map so that the
user
>> can't miss seeing them. I've had trouble getting the layerswitcher
to
>> appear where and how I want it when placing it outside the map, and I
>> think the standard layerswitcher tool inside the map is too "hidden"
for
>> the likely users of this map.
>> 2) Clicking a radiobutton needs to change the style that the towns
layer
>> uses to symbolize itself, update the legend graphic, and add a title
>> above the legend. I'm not sure if the layerswitcher can trigger the
>> latter two.
>> 3) The way I've implemented this is to have one Layer in the map for
>> each radiobutton. Clicking on a radiobutton makes all layers but
that
>> one invisible. I'm open to different approaches if anyone can think
of
>> one.
>> 4) What's going wrong is that the radiobuttons don't properly change
the
>> layer. Clicking on them works at first, but then if you pan or zoom
>> there is no redraw, because subsequent server requests are asking for
>> the top/original layer, not the user-selected layer.
>> I would greatly appreciate any reply!
>> Thanks!
>> --David
>> Subject: Toggling layers without LayerSwitcher
>> Hi everyone,
>> I'm working on my first OpenLayers map and I'm having a problem with
>> toggling layer visibility. I want to use an HTML form with
radiobuttons
>> to toggle the layers instead of the LayerSwitcher control. When I
>> choose a layer other than the first layer in the list, it draws fine
>> once but if you do any zooming or panning it will not redraw. If you
>> choose the first layer, it works fine. Here's the map:
>> http://maps.massgis.state.ma.us/dcr/forestry09.html
>> The function that chooses the new layer is called changeSymbolization
>> (it's called by the radiobuttons' change event). It loops through
the
>> layers and makes all but one invisible.
>> lz = map.layers;
>> for (n=0; n < lz.length; n++) {
>> lz[n].setVisibility(lz[n].name ==
>> byFieldSplit[0]);
>> byFieldSplit[1];
>> [this function is called by radiobuttons, for example]:
>> <input type="radio" name="chosenSymbology"
>> onclick="changeSymbolization(this.value)" value="FSCARS_SC,Towns
>> symbolized by<br/>National Forest Service<br/>CARS Score:" /> Federal
>> CARS score<br />
>> After trying a few approaches, I set it up so there are 17 different
>> layers added to the map, each of which contains all the background
>> layers plus the foreground layer (which is symbolized by a different
>> attribute in each layer). This is done in the init() function. I'm
not
>> sure this is the best way to do it, but when I tried having the
>> background and foreground layers in separate layers, the foreground
>> layer would block the background layers by drawing a white background
on
>> the whole map before drawing the foreground layer.
>> [Here is what each layer looks like (there are 17 of these, each with
a
>> different name and different Style for one of the layers)]:
>> IMPERV_PCT_Layer = new OpenLayers.Layer.WMS(
>> "IMPERV_PCT",
>> "http://giswebservices.massgis.state.ma.us/geoserver/wms",
>> width: '600',
>> srs: 'EPSG:26986',
>> layers:
'massgis:DCR.TOWNS_POLYM_FORESTRY,massgis:GISDATA.OCEANMASK_POLY,massgis
:GISDATA.NEMASK_POLY,massgis:DCR.TOWNS_POLYM_FORESTRY,massgis:GISDATA.TO
>> WNS_POLY',
>> height: '358',
>> styles:
',,GISDATA.NEMASK_POLY::Light_Yellow,DCR.TOWNS_POLYM_FORESTRY::IMPERV_PC
>> T,GISDATA.TOWNS_POLY::Labels_Med',
>> format: 'image/png'
>> {singleTile: true, ratio: 1}
>> IMPERV_PCT_Layer.setVisibility(0);
>> [Here is how they're added to the map]:
map.addLayers([SUSTCOM_SC_Layer,FSCARS_SC_Layer,ST_ASST_YN_Layer,MGTPLAN
_YN_Layer,ADV_GRP_YN_Layer,LOC_ORD_YN_Layer,PROSTAF_YN_Layer,TREEINV_YN_
Layer,TREECITYYN_Layer,OSPLAN_YN_Layer,PDENSQMI00_Layer,BUDGET_P_C_Layer
,UFORE_YN_Layer,STRATUM_YN_Layer,UCF_INDEX_Layer,CANOPY_COV_Layer,IMPERV
>> _PCT_Layer]);
>> I tried to find a similar example somewhere, but they seem to use the
>> layerswitcher control and be really simple (Examples) or be so
complex
>> that I couldn't make heads of tails of them (Gallery).
>> Does anyone have a suggestion for how to fix the redrawing problem,
or a
>> better approach to dealing with the layer switching that would solve
the
>> problem? Thank you for your help!
>> --David
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
