[OpenLayers-Users] 2.7 EditingToolbar.js and Naviagtion.js Error
Eric Lemoine
eric.c2c at gmail.com
Wed Oct 8 17:49:00 EDT 2008
Well, I'm not sure this is a bug. To me the editing toolbar is a kind
of convenience class for adding editing capabilities to your map. If
you don't like its behavior then you're free to implement your own
editing panel. Eric
2008/10/3, David Martin <David at itbeyond.com.au>:
> Hi,
> I have spent some time looking into this and have found a problem. I am
> a little confused about the best solution but here is the bug report:
> When you have add a navigation control and disable the mouse wheel using
> this (the rightclick handler makes no difference to the problem):
> map.addControl(new OpenLayers.Control.Navigation({ 'zoomWheelEnabled':
> false, 'handleRightClicks': true }));
> Then you load an EditingToolbar using:
> map.addControl(new OpenLayers.Control.EditingToolbar(vectors));
> The zoomWheel becomes enables again on the map. I did some experiements
> and did not load the EditingToolbar (the wheel was disabled as expected)
> and added a button on a test page to enable the EditingToolbar and as
> soon as it is enabled to the zoomWheel becomes active on the map.
> I looked into the EditingToolbar.js file and found this section which I
> think is causing the problem:
> initialize: function(layer, options) {
> OpenLayers.Control.Panel.prototype.initialize.apply(this,
> [options]);
> this.addControls(
> [ new OpenLayers.Control.Navigation() ]
> var controls = [
> new OpenLayers.Control.DrawFeature(layer,
> OpenLayers.Handler.Point, {'displayClass':
> 'olControlDrawFeaturePoint'}),
> OpenLayers.Handler.Path, {'displayClass': 'olControlDrawFeaturePath'}),
> OpenLayers.Handler.Polygon, {'displayClass':
> 'olControlDrawFeaturePolygon'})
> for (var i=0, len=controls.length; i<len; i++) {
> controls[i].featureAdded = function(feature) { feature.state
> = OpenLayers.State.INSERT; };
> this.addControls(controls);
> It appears we are basically reloading the Navigation control using
> default settings and thus enabling the zoomWheel. Interesting enough
> the rightClick zoom out function still works so this has not been
> overridden. I am unsure how to proceed with this bug and was thinking
> that the best solution is to look into the controls array to see if
> Navigation is already loaded and not load it again, however I wonder if
> the EditingToolbar.js should even be loading the Navigation control.
> PS: It does not seem to matter which order you load the controls as the
> nor does it matter if you turn off the vectors overlay the zoomWheel
> just continues to work.
> Regards
> David Martin
> Managing Director
> I.T. Beyond Pty Ltd
> Postal:
> PO BOX 967
> HILLARYS WA 6923
> Ph:
> (08) 9403 3737
> Mobile:
> 0417 677 275
> Fax:
> (08) 9403 3738
> Skype:
> itbeyond_david
> ________________________________
> Check out our websites: www.ExplorOz.com <http://www.exploroz.com/> and
> www.itbeyond.com.au <http://www.itbeyond.com.au/>
