[OpenLayers-Users] OL 2.7 Marjers Feature Style_map
Eric Lemoine eric.c2c at gmail.com
Thu Oct 9 12:49:09 EDT 2008
Hi.
StyleMap applies to Layer.Vector only.
I'm not sure I understand your problem with vector feature selection.
You want to be able to select one feature without unselecting other
selected features; is that it?
With the select feature control you can do that with some option and
by pressing the SHIFT key during selection. I'm not sure you can
configure the select feature control to enable multi selection without
having to press any modifier key (I have to check); if not it
shouldn't be that hard to build your own select feature control. Look
at the select feature control code if you want to follow that path.
Cheers
Eric
2008/10/9, Walter Lorenzetti <lorenzetti at gis3w.it>:
> Hi all,
> I don't know if is it possible:
> watching on news 2.7 example I found markers_shadow.html
> Is fantastic for my new application where now I use icon image just with
> shadow...
> I see that now is possible to setup a stylemap obj for a vector layer ong
> but I've a problem
> in my application I parse a gml file to put a markers layer on the map:
> 1) I parse the gml file
> 2) I build several OpenLayers.Feature obj
> 3) I add several metadata from parse file to my new features and new
> icon on .data.icon and a popup object
> 4) from the new features I build markes
> 5) for every marker I register a function on click event
> marker.events.register ("click") for show a popup
> 6) at the end I put all my new markers in a mew marker layer obj
> I do that because on a more simple vector layer is too difficult
> register a click event
> because I can only select the single feature...
> so my question is:
> Is possible apply the stylemap method to a OpenlayersFeature?
> Or with a vector layer obj is there a symple method for a click event?
> I hope my english is not too bad
> Thanks in advance
> Walter
> Walter Lorenzetti
> email: lorenzetti at gis3w.it
> skype: aiki74
> Cell: (+39) 347-6597931  Tel+Fax: (+39) 0583 926684
> Via di Tofori 123a 55010, Camigliano-S.Gemma Lucca
> Italy
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
