[OpenLayers-Users] parse GML v3 with OpenLayers.Format.GML.v3
Tim Schaub
tschaub at opengeo.org
Fri Oct 10 20:34:30 EDT 2008
Hey-
Please open a ticket with this detail and assign it to me.
Thanks,
Tim
Alexandre Dube wrote:
> Hi,
> I'm currently trying the Protocol.WFS new features and I'm facing a
> similar problem. I use TinyOWS 0.6.0 and OL 2.7.
> I've followed the wfs-protocol-transactions example to reproduce the
> same kind of actions ( add-modify features ) Here's the post request
> that OL produces for my application :
> <wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
> version="1.0.0" outputFormat="GML2">
> <wfs:Insert>
> <feature:bdga_route_l_arc xmlns:feature="http://127.0.0.1:9999/">
> <feature:the_geom>
> <gml:MultiLineString xmlns:gml="http://www.opengis.net/gml"
> srsName="EPSG:32198">
> <gml:lineStringMember>
> <gml:LineString>
> <gml:coordinates decimal="." cs="," ts="
> ">-389909.9750701957,184819.27638712854
> -390597.89136538754,183513.99931420037</gml:coordinates>
> </gml:LineString>
> </gml:lineStringMember>
> </gml:MultiLineString>
> </feature:the_geom>
> </feature:bdga_route_l_arc>
> </wfs:Insert>
> </wfs:Transaction>
> This post is very similar the the post produced by the
> wfs-protocol-transactions example. But, the example uses Geoserver and
> no error occurs. Tinyows gives 2 errors :
> ==> element Transaction: Schemas validity error : Element
> '{http://www.opengis.net/wfs}Transaction', attribute 'outputFormat': The
> attribute 'outputFormat' is not allowed.
> ==> element bdga_route_l_arc: Schemas validity error : Element
> '{http://127.0.0.1:9999/}bdga_route_l_arc': This element is not
> expected. Expected is one of ( {http://www.opengis.net/gml}_Feature,
> {http://www.opengis.net/wfs}FeatureCollection ).
> Both means that the schema WFS-transaction is not respected... I
> don't know why it works with GeoServer, but I think it shouldn't.
> Normand ( one of my co-workers ) modified TinyOWS to make it ignore
> schema errors, and then it works fine. But, I think that's not a good
> solution. The post request should respect the schema. It should looks
> more like Sébastien's first post, with "<gml:FeatureColletion>" and all.
> So far, I tried GML3 and also tried to edit OL code to change this
> behavior, but without success.
> Any comments / suggestions / hints would be appreciated, please.
> Alexandre
> Eric Lemoine wrote:
>> Hi Seb. I'd have expected the GML format to automatically pick the
>> appropriate format version for you, but apparently not. Does your GML
>> file advertise the correct version number? Cheers. Eric
>> 2008/10/10, Sébastien Geindre <sebastien.geindre at meteo.fr>:
>>> It works better with :
>>> <gml:featureMembers .....>
>>> <wims:tma>
>>> <wims:geometry>
>>> <gml:Polygon srsName="EPSG:4326">
>>> <gml:exterior>
>>> <gml:LinearRing>
>>> <gml:posList>49.97 0.67 49.97 3.90 47.66 3.90
>>> 47.66 0.67 49.97 0.67</gml:posList>
>>> </gml:LinearRing>
>>> </gml:exterior>
>>> </gml:Polygon>
>>> </wims:geometry>
>>> </wims:tma>
>>> </gml:featureMembers>
>>> and
>>> var tma = new OpenLayers.Layer.GML("CDG TMA", "tmaCDG.gml",
>>> format: OpenLayers.Format.GML.v3,
>>> formatOptions : {
>>> featureType: "tma",
>>> featureNS: "http://www.flysafe-eu.org/wims",
>>> geometryName: "geometry",
>>> srsName: "urn:x-ogc:def:crs:EPSG:4326",
>>> schemaLocation: "http://www.flysafe-eu.org/wims memo.xsd"
>>> Sébastien Geindre a écrit :
>>>> hello all,
>>>> In OL2.7, I try to parse a simple GML v3 feature, but it does not work.
>>>> var tma = new OpenLayers.Layer.GML("CDG TMA", "tmaCDG.gml", {format:
>>>> OpenLayers.Format.GML.v3});
>>>> the file tmaCDG.gml :
>>>> <?xml version="1.0" encoding="URF-8"?>
>>>> <gml:FeatureCollection xmlns:gml="http://www.opengis.net/gml">
>>>> <gml:featureMember>
>>>> <gml:exterior>
>>>> <gml:LinearRing>
>>>> <gml:posList>49.97 0.67 49.97 3.90 47.66 3.90 47.66 0.67 49.97
>>>> 0.67</gml:posList>
>>>> </gml:LinearRing>
>>>> </gml:exterior>
>>>> </gml:Polygon>
>>>> </gml:featureMember>
>>>> </gml:FeatureCollection>
>>>> The file is well-parsed but features in GML.js line 139 is empty...
>>>> this.readNode(elements[i], {features: features});
>>>> is there any example of parsing GML v3 ?
>>>> thanks
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
>> Users mailing list
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
