[OpenLayers-Users] Clustering and addFeatures method
Jacolin Yves
yjacolin at free.fr
Tue Oct 21 08:23:38 EDT 2008
Le Thursday 16 October 2008 17:31:19 Eric Lemoine, vous avez écrit :
> Hi Yves. I don't see anything wrong with what you're doing. So you're
> saying you are adding two features (far from each other), and
> nevertheless see only one of the two on the map, right? Could you cook
> up a small example so that we can reproduce the problem. Eric
> 2008/10/16, Jacolin Yves <yjacolin at free.fr>:
> > Hello,
> > I am trying to set up a cluster strategy for one of my vector layer. I
> > add this code to my existing code:
> > var vector = new OpenLayers.Layer.Vector(name,
> > strategies: [
> > new OpenLayers.Strategy.Cluster({distance:20})
> > Before this, the code was " var vector = new
> > OpenLayers.Layer.Vector(name);"
> > I fill my vectorLayers later, reading a postgis result with:
> > var feature = wktParser.read(_tmp[1]);
> > vectorLayer.addFeatures([ feature ]);
> > I get only one feature (instead of 2) for all the zoom level. I tried to
> > change the distance option above, but nothing append. If I check the DOM,
> > nothing show me that there are more than 1 feature in this layer.
> > Where am I wrong?
> > Y.
> > PS : the code is much more longer than here and is split in several
> > functions
> > so I can't show you all in once, I tried to put the most readable as
> > possible.
Hi Eric,
Here is an example of my OpenLayer map with cluster strategies:
http://softlibre.free.fr/ol/test.html
Thanks for any help!
Y.
Yves Jacolin
http://softlibre.gloobe.org
