[OpenLayers-Users] Clustering and addFeatures method
Eric Lemoine
eric.c2c at gmail.com
Tue Oct 21 10:46:21 EDT 2008
On Tue, Oct 21, 2008 at 2:23 PM, Jacolin Yves <yjacolin at free.fr> wrote:
> Le Thursday 16 October 2008 17:31:19 Eric Lemoine, vous avez écrit :
>> Hi Yves. I don't see anything wrong with what you're doing. So you're
>> saying you are adding two features (far from each other), and
>> nevertheless see only one of the two on the map, right? Could you cook
>> up a small example so that we can reproduce the problem. Eric
>> 2008/10/16, Jacolin Yves <yjacolin at free.fr>:
>> > Hello,
>> > I am trying to set up a cluster strategy for one of my vector layer. I
>> > add this code to my existing code:
>> > var vector = new OpenLayers.Layer.Vector(name,
>> > strategies: [
>> > new OpenLayers.Strategy.Cluster({distance:20})
>> > Before this, the code was " var vector = new
>> > OpenLayers.Layer.Vector(name);"
>> > I fill my vectorLayers later, reading a postgis result with:
>> > var feature = wktParser.read(_tmp[1]);
>> > vectorLayer.addFeatures([ feature ]);
>> > I get only one feature (instead of 2) for all the zoom level. I tried to
>> > change the distance option above, but nothing append. If I check the DOM,
>> > nothing show me that there are more than 1 feature in this layer.
>> > Where am I wrong?
>> > Y.
>> > PS : the code is much more longer than here and is split in several
>> > functions
>> > so I can't show you all in once, I tried to put the most readable as
>> > possible.
> Hi Eric,
> Here is an example of my OpenLayer map with cluster strategies:
> http://softlibre.free.fr/ol/test.html
Doesn't work. OpenLayers.js cannot be loaded, isn't
www.lpdipro2.dev.local on a private network?
Eric
