[OpenLayers-Users] Cannot deactivate
OpenLayers.Control.PanZoomBar
bartvde at osgis.nl
bartvde at osgis.nl
Mon Oct 27 06:40:46 EDT 2008
PanZoomBar has no activate/deactivate.
The only thing I can think off (but is kind of hacky) is to make sure the
events are not registered on the panzoombar, something like (ctrl is your
PanZoomBar control):
ctrl.sliderEvents.destroy();
ctrl.sliderEvents = null;
ctrl.divEvents.destroy();
ctrl.divEvents = null;
You can also try using removeControl on the map object, but it will remove
your panzoombar totally from the map div, so I don't know if this
acceptable for your use case.
Best regards,
Bart
> Hallo,
> I'd like to freeze my OpenLayers.Map.
> I thought, that if I deactivate the navigation and the
> panzoombar-controls,
> I would get the wished result.
> Yet, after deactivating the panzoombar control, I can still use it.
> Thanks for your help.
> Florian
> http://n2.nabble.com/Cannot-deactivate-OpenLayers.Control.PanZoomBar-tp1381757p1381757.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
