[OpenLayers-Users] Vector feature attribute name
Alexandre Dube
adube at mapgears.com
Mon Oct 27 10:00:24 EDT 2008
Hi list,
I have a little problem with attribute names for vector features. In
my application, I have 2 data sources ( shapefiles and postGIS ) that
share the exact same kind of data. The only difference is the attribute
names, which are respectively in uppercase and lowercase ( ex. :
RES_CO_REG, res_co_reg )
My application must interact in both ways they are written ( or
preferably, ANY way they are written), so before using an attribute
name, I use this little function I've written :
OpenLayers.Feature.Vector.prototype.getAttributeName = function (szName) {
szName = szName.toUpperCase();
var szAttribute, key;
for ( key in this.attributes ) {
szAttribute = key.toUpperCase();
if (szAttribute == szName)
return key;
return false;
This works on feature objects. I didn't find a way to do it otherwise.
Like when using the addUniqueValueRules function, I have to do the
following :
oRegStyleMap.addUniqueValueRules("default", "RES_CO_REG", aRegColor);
oRegStyleMap.addUniqueValueRules("default", "res_co_reg", aRegColor);
To me, it seems like my solution is a big waste of time ( having to
loop into each attribute name every time )... Is there a better way to
do it ?
Alexandre Dubé
Mapgears
www.mapgears.com
