[OpenLayers-Users] Putting map-div in a table won't work
Kenneth Johnsen
kejster at gmail.com
Wed Sep 3 04:16:24 EDT 2008
Ah! That was the problem.
Thank you very much.
Regards, Kenneth.
2008/9/2 Andrew de Klerk <andrew.deklerk at gmail.com>
> Does your map div have a style with width and height set? - i.e.
> #map{
> width:500px;
> height:500px;
> border:1px solid;
> Other than that, I We have placed ours in a table before - so that should
> not be a problem. I may be missing something, but your code looks ok
> The div is a normal html div so you should be able to position it through
> styles
> -----Original Message-----
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> On
> Behalf Of kejster
> Sent: 02 September 2008 08:21 PM
> To: users at openlayers.org
> Subject: [OpenLayers-Users] Putting map-div in a table won't work
> I am very new to Openlayers, so I thought I would play around with one of
> the
> examples (the Google with overlay one).
> I can get that to work OK, but then I though I'd try to position the div
> where the map is show.
> I tried two ways: using a stylesheet ( #map { position: ...... ) and a
> table.
> Neither of these things work. I just see a blank page.
> Below is my code for the one I did with the table.
> Can anyone tell me if I'm just doing something wrong, or does OpenLayers
> not
> allow you to mess with the position of it's div?
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <title>Untitled Page</title>
> <script
> src='
> http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGe
> m0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ<http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ>
> '></scri
> pt>
> <script src="JavaScript/OpenLayers.js"></script>
> <script type="text/javascript">
> var map;
> function init(){
> map = new OpenLayers.Map('map');
> var satellite = new OpenLayers.Layer.Google(
> "Google Satellite" , {type: G_SATELLITE_MAP}
> var wms = new OpenLayers.Layer.WMS(
> "World Map",
> "http://world.freemap.in/cgi-bin/mapserv",
> map: '/www/freemap.in/world/map/factbooktrans.map',
> transparent: 'TRUE',
> layers: 'factbook'
> {'reproject': true}
> map.addLayers([satellite, wms]);
> map.setCenter(new OpenLayers.LonLat(10.205188,48.857593), 5);
> map.addControl( new OpenLayers.Control.LayerSwitcher() );
> </script>
> </head>
> <body onload="init();">
> <table>
> <tr>
> <td>Some text</td>
> </tr>
> <tr>
> <td>
> <div id="map"></div>
> </td>
> </tr>
> </table>
> </body>
> </html>
> http://n2.nabble.com/Putting-map-div-in-a-table-won%27t-work-tp834581p834581
> .html<http://n2.nabble.com/Putting-map-div-in-a-table-won%27t-work-tp834581p834581.html>
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.169 / Virus Database: 270.6.14/1647 - Release Date: 9/2/2008
> 6:02 AM
> Users mailing list
Med venlig hilsen / Best regards,
Kenneth Johnsen.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080903/821867d2/attachment.html
