[OpenLayers-Users] Zoom to a Layer's Extent
Bill Thoen
bthoen at gisnet.com
Mon Sep 8 11:27:03 EDT 2008
Christopher Schmidt wrote:
>>> In 2.7RC1 (just released) you can use getDataExtent() for that. (We
>>> didn't add getDataExtent for vector layers until after 2.6.)
>>> Also, using 2.7RC1 would help us get more 2.7 testing :)
I checked again and it doesn't seem to work with WFS layers at least.
If you look at http://206.168.217.244/zoomToLayerExtents.html, you'll
see what I mean.
In this example, (using 2.7RC1) I open a base layer of the US from
MapServer and then open an overlay layer of a pipeline network from a
MapServer WFS. Then I set up a listener to call the function
layerLoaded() on the loadend event (so that the layer has its features
array populated.) Finally, in layerLoaded I call map.zoomToExtent
(layer.getDataExtent()), but the map doesn't zoom. The commented out
call to zoomToLayerExtents() right next to that line actually does what
I want (which is to zoom into the area covered by the pipeline layer.)
So is this a bug with getDataExtent() or is it working as its should and
I'm just using it wrong?
- Bill Thoen
