[OpenLayers-Users] Need explanations : minScale/maxScale with
scales set on map
Alexandre Dube
adube at mapgears.com
Mon Sep 8 16:31:30 EDT 2008
That's what I thought... Thank you very much, Eric.
Alexandre
Eric Lemoine wrote:
> Hi. It looks like that if you set minScale/maxScale OpenLayers takes
> it as "calculate the intermediate resolutions". I cannot think of
> something better than pass your layer a scale array. I may be missing
> it though. Cheers. Eric
> 2008/9/8, Alexandre Dube <adube at mapgears.com>:
>> Hi everybody,
>> I need some explanations regarding minScale/maxScale with 'scales'
>> array set on map, please.
>> Release/2.7/Note
>> Layer :
>> minScale' and 'maxScale' properties no longer ignored if 'scales'
>> array set on map. (#1199 <http://trac.openlayers.org/ticket/1199>)
>> Yeah, they are not ignored, but only both theses scales correspond the
>> actual map scales, not the ones between them.
>> For example, I have the following scales set for my map :
>> scales: [13000000, 8000000, 4000000, 2000000, 1000000, 500000, 250000,
>> 100000, 50000, 25000, 10000]
>> If I set minScale: 1000000, maxScale: 100000 to a layer and then check
>> its scales array, I get the following :
>> index : value
>> 0 : 1000000.0000000001
>> 1 : 464158.8833612779 // instead of 500000
>> 2 : 215443.46900318837 // instead of 250000
>> 3 : 99999.99999999999
>> I can understand how theses values are set this way.
>> I don't know why they do.
>> Are the values ok ? Will this affect anything ? ( because they are
>> different than the scales from the map )
>> I don't understand why the layer could not have the values in the scales
>> array of the map directly instead of calculating its own...
>> Sorry for the long e-mail. I only need some explanations, please.
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
