[OpenLayers-Users] Validate polygon
Alexandre Dube
adube at mapgears.com
Wed Sep 10 14:44:22 EDT 2008
Hi Bas,
You can check the geometry object of your feature. You'll find a
Polygon object which has points and there you can check the first and
the last if they have the same coordinates.
yourFeature.geometry.components[0].components[0].x // the first point.x
yourFeature.geometry.components[0].components[0].y // the first point.y
yourFeature.geometry.components[0].components[last].x // the last
point.x
point.y
Hope this helps,
Alexandre
Bas Couwenberg wrote:
> Hello,
> is there a way in OpenLayers to check if a feature is a valid Polygon?
> I want to check it the start and end point are the same coordinate and
> such.
> Best regards,
> Bas Couwenberg
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
