[OpenLayers-Users] Can't get VE map to work
Erik Uzureau
euzuro at gmail.com
Sun Sep 14 11:57:28 EDT 2008
Yup,
The problem is that you are requestion v6.1 of the VE library, and yet you are
requesting the current API version of OpenLayers... which is v2.6.
In the 2.6 release of OL, we had not updated the VE layer to work correctly
with the latest versions of the VE Library.
If you change your rOL script include to point to the latest release (2.7rc2)
<script src="http://openlayers.org/api/2.7-rc2/OpenLayers.js"></script>
..then VE will work -- AND you'll get to help us out testing the RC!
The 2.7 release will be out at the end of September, if not sooner.
Cheers,
Erik
On Sun, Sep 14, 2008 at 10:18 AM, Lennox Antoine <lxnyce at gmail.com> wrote:
> I am hoping someone can make better sense out of this than I. I copied the
> example map here :
> http://openlayers.org/dev/examples/ve.html
> I moved it to my server, and changed the links to point back to the correct
> locations : http://vizure.net/tests/ol/map.html
> This test gives me a constant error in the Firefox error console : "Error:
> Msn.VE.Pixel is not a constructor"
> I tried hosting everything myself initially, but that doesn't work either,
> it's the same error : http://vizure.net/tests/ol/map2.html
> So I am kind of lost now. Any ideas as to why VE would not work, but
> everything else does?
> Lennox
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
