[OpenLayers-Users] Can't get VE map to work
Lennox Antoine
lxnyce at gmail.com
Sun Sep 14 12:16:55 EDT 2008
Thanks a ton, it finally works now.
On Sun, Sep 14, 2008 at 11:57 AM, Erik Uzureau <euzuro at gmail.com> wrote:
> Yup,
> The problem is that you are requestion v6.1 of the VE library, and yet you
> are
> requesting the current API version of OpenLayers... which is v2.6.
> In the 2.6 release of OL, we had not updated the VE layer to work correctly
> with the latest versions of the VE Library.
> If you change your rOL script include to point to the latest release
> (2.7rc2)
> <script src="http://openlayers.org/api/2.7-rc2/OpenLayers.js"></script>
> ..then VE will work -- AND you'll get to help us out testing the RC!
> The 2.7 release will be out at the end of September, if not sooner.
> Cheers,
> Erik
> On Sun, Sep 14, 2008 at 10:18 AM, Lennox Antoine <lxnyce at gmail.com> wrote:
> > I am hoping someone can make better sense out of this than I. I copied
> the
> > example map here :
> > http://openlayers.org/dev/examples/ve.html
> > I moved it to my server, and changed the links to point back to the
> correct
> > locations : http://vizure.net/tests/ol/map.html
> > This test gives me a constant error in the Firefox error console :
> "Error:
> > Msn.VE.Pixel is not a constructor"
> > I tried hosting everything myself initially, but that doesn't work
> either,
> > it's the same error : http://vizure.net/tests/ol/map2.html
> > So I am kind of lost now. Any ideas as to why VE would not work, but
> > everything else does?
> > Lennox
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080914/b9f2b498/attachment.html
