[OpenLayers-Users] Vector layer - number of circles
Vivien Deparday vivien.deparday at gmail.com
Fri Apr 3 20:24:24 EDT 2009
Hi Brad,
You are right, it is because the number of features is too important (
see the faq in the section vector
<http://faq.openlayers.org/vector-related-questions/what-is-the-maximum-number-of-coordinates-features-i-can-draw-with-a-vector-layer/>).
One solution is to use the cluster strategy, it will speed up your
display (see the two examples: http://openlayers.org/dev/examples/ ) If
you don't want to cluster your features, another solution would be to
use a simple wms for big extents and then use your vector layer with a
BBOX strategy for smaller extent. That way only the features in the
visible extent will be requested (see also the example). That all I came
up with, maybe someone will have a better idea...
Hope it helps,
Vivien
Brad Spencer wrote:
> I have built a file upload and display feature that generates a
> temporary vector layer [as if markers] that are a series of graduated
> circles with mouseover popups. This works like a treat for relatively
> small files of points. But if I load a lot of points [over 2,000] it
> takes a long time to load and panning and zooming is very slow. I
> assume its just the number of local vectors.
> Is there any techniques that I could use to improve load times as well
> as navigation refreshes?
> Cheers, Brad….
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
