[OpenLayers-Users] OpenLayers - mixing Google and other projections - seeking an example?
Christopher Schmidt crschmidt at metacarta.com
Fri Apr 10 08:15:57 EDT 2009
On Fri, Apr 10, 2009 at 12:36:35AM -0600, Greg Cocks wrote:
> Hello Again,
> I am trying to better learn how the Google projection works when mixed
> with other datasets in an OpenLayers 'function'. I have built OpenLayers
> 'functions' that bring them all in - but as you know they need to be
> reprojected.
> * If someone could be good enough to provide a 'working example' of
> something that works for them I would be very appreciative * - i.e.,
> that mixes Google et. al. and other projections, 'public' datasets,
> raster & vector ideally, maybe 'cut & paste' into an email reply?
It's probably best if you go the other way. Provide what you hae, and
let someone work from that. There are a Lot of different configurations
out there.
http://openlayers.org/dev/examples/sundials-spherical-mercator.html is
my canonical example, which is Google/OSM and KML, which is the basic
example that people can use.
> I could then poke and prod at it, dissect it, mess with it - all those
> good ways you do as learn something new.
> Note that I would NOT be bothering you with questions if you were good
> enough to supply an example - I just wanted a starting point for me to
> get my head around this.
> I have course found examples of this online - but for whatever reason,
> they seem not to be as complete as I hoped / 'needed.' I learnt that the
> Google datasets should be the 'native' projection in the OpenLayers
> function and have tried to make it work but haven't had that "ah ha"
> moment yet.
> Thank you in advance.
> I do have OpenLayers running under IIS 7 by the way...
> Anyway, I know those of you who are subscribed are of course NOT tech
> support - I just wanted to get your impression/s (i.e., before my
> keyboard leaves permanent impressions on my forehead!)
> Thanks in advance...
> Regards,
> GREG COCKS
> Data Management Specialist / Scientist / GIS Analyst IV
> gcocks at stoller.com <blocked::mailto:gcocks at stoller.com>
> S. M. Stoller Corp
> 105 Technology Drive, Suite 190
> Broomfield, CO 80021
> www.stoller.com <blocked::http://www.stoller.com/>
> 303-546-4300
> 303-443-1408 fax
> 303-546-4422 direct
> 303-828-7576 cell
> Tilecache mailing list
> Tilecache at openlayers.org
> http://openlayers.org/mailman/listinfo/tilecache
> Regards,
> GREG COCKS
> S. M. Stoller Corp
> 303-546-4300
> 303-443-1408 fax
> 303-546-4422 direct
> 303-828-7576 cell
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
