[OpenLayers-Users] FW: Download image(bitmap)
Marco Ferretti
marco.ferretti at fermasoft.com
Sat Apr 18 04:13:27 EDT 2009
Hi
first of all you have to tell us a little bit more on how
you create your map : is it a single layer map or a
multilayer map ? then we need to know if you are getting the
map in single tile mode or in multi tile mode. Then we need
to know what you expect in the image(s) you download : do
you expect your users to be able to download exactly what
their browser show ( this would mean as many images as many
tiles * number of layers ) or do you expect to have one
single image that contains the layers merged together ?
Regards,
Marco
----- Original Message -----
Da : Kwong Hu Kiu <kwonghu at hotmail.com>
A : <marco.ferretti at fermasoft.com>, <users at openlayers.org>
Oggetto : RE: [OpenLayers-Users] FW: Download image(bitmap)
Data : Sat, 18 Apr 2009 16:07:30 +0800
> Thanks for the reply.
> So how can i do that with javascript ? Yes, i have my own
> custom wms service.
> I want to be able to download the map using javascript
> like you said.
> Cheers.
> > From: marco.ferretti at fermasoft.com
> > To: kwonghu at hotmail.com
> > Subject: re: [OpenLayers-Users] FW: Download
> > image(bitmap) Date: Sat, 18 Apr 2009 09:52:43 +0200
> > Hi
> > I don't think i understood your question .... if you
> > want to be able to download stuff that you see you have
> > several options ( depending on how you created the map
> > ... aka how many layers you have ) ; I think what you
> > are looking for is a link that has to contain the same
> > stuff you send to the WMS server . That shall be quite
> > easy using Javascript . As of C# : i don't think you
> > have to deal with it since what you see ( the maps ) is
> > the result of an http request made client side thus,
> > unless you create a wrapper that submits your server
> > side code all the infos you need, you can do very little
> > with that.
> > hope it helps
> > Marco
> > A : <users at openlayers.org>, <dev at openlayers.org>
> > Oggetto : [OpenLayers-Users] FW: Download image(bitmap)
> > Data : Sat, 18 Apr 2009 13:22:52 +0800
> > > Hi,
> > > Any solution to my question below?
> > > Sorry i have to send it to dev at openlayers.org.
> > > Hopefully, i can get some replies.
> > > Regards.
> > > From: kwonghu at hotmail.com
> > > To: users at openlayers.org
> > > Date: Thu, 16 Apr 2009 21:20:53 +0800
> > > Subject: [OpenLayers-Users] Download image(bitmap)
> > > Hi,
> > > Currently, I am using WMS service to display maps on
> > > openlayers. I am wondering if it's possible to allow
> > > users to download the bitmap(Map) they are seeing.
> > > Is it supported with openlayers ? or is it possible to
> > > use c# code and interact with openlayers javascript?
> > > Interacting c# and javascript is something I have no
> > > idea.
> > > Please shed lights.
> > > Cheers.
> > > _______________________________________________
> > > Users mailing list
> > > Users at openlayers.org
> > > http://openlayers.org/mailman/listinfo/users
> > > [Allegato : ATT00000]
