[OpenLayers-Users] vector popups misaligned after resize &
switching of google layers (with fix for Ticket #1797 applied)
RFeagin
ryan.feagin at PEACHTREEGEOGRAPHICS.COM
Thu Apr 23 15:29:28 EDT 2009
as a quick workaround, I'm catching the changebaselayer event and doing
map.pan(-1, -1); to force the map to realign properly.
RFeagin wrote:
> My vector points are staying aligned with the baselayer. I'm only having
> a problem with the popup on the first hover after the resize and layer
> switch.
> Vivien Deparday wrote:
>> Hi,
>> I encounter a similar behaviour. I've reported it at the end of the
>> Ticket #1797.
>> So far, I didn't have time to dig into the code to try to make a clean
>> fix.
>> I have made a very non-satisfactory makeshift fix which is to add :
>> this.layer.map.moveTo(this.layer.map.getCenter()); at the line 360 of
>> the layerswitcher control.
>> But I will open a new ticket.
>> Are you vector features misaligned with your baselayer too or is it only
>> the popup?
>> Cheers,
>> Vivien
>> RFeagin wrote:
>>> The google resizing and switching layers(Ticket #1797) has been a
>>> problem for
>>> me in one of my applications. I saw that 2.8 RC1 had a fix for it, so I
>>> grabbed the google.js from the 2.8 RC1 and tried using it with my 2.7
>>> code.
>>> I didn't see anything in the changes that looked like it would cause a
>>> problem.
>>> Here is what I ran into... I have a point vector layer with hover popups
>>> using SelectFeature on top of google layers with sphericalMercator =
>>> true.
>>> When I follow the steps listed on the ticket to test the fix, the map
>>> now
>>> resizes correctly (thanks) but the first time I hover over a vector, the
>>> popup is in the wrong location. So it looks like the map tiles and
>>> vectors
>>> are realigning after the resize, but the popups aren't.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/vector-popups-misaligned-after-resize---switching-of-google-layers-%28with-fix-for-Ticket--1797-applied%29-tp2664930p2685438.html
