[OpenLayers-Users] vector popups misaligned after resize &
switching of google layers (with fix for Ticket #1797 applied)
Andreas Hocevar
ahocevar at opengeo.org
Thu Apr 23 16:52:35 EDT 2009
I uploaded a new patch for #1797. Can someone please apply it and see if
it improves things, commenting any findings on the ticket?
Thanks,
Andreas.
RFeagin wrote:
> as a quick workaround, I'm catching the changebaselayer event and doing
> map.pan(-1, -1); to force the map to realign properly.
> RFeagin wrote:
>> My vector points are staying aligned with the baselayer. I'm only having
>> a problem with the popup on the first hover after the resize and layer
>> switch.
>> Vivien Deparday wrote:
>>> Hi,
>>> I encounter a similar behaviour. I've reported it at the end of the
>>> Ticket #1797.
>>> So far, I didn't have time to dig into the code to try to make a clean
>>> fix.
>>> I have made a very non-satisfactory makeshift fix which is to add :
>>> this.layer.map.moveTo(this.layer.map.getCenter()); at the line 360 of
>>> the layerswitcher control.
>>> But I will open a new ticket.
>>> Are you vector features misaligned with your baselayer too or is it only
>>> the popup?
>>> Cheers,
>>> Vivien
>>> RFeagin wrote:
>>>> The google resizing and switching layers(Ticket #1797) has been a
>>>> problem for
>>>> me in one of my applications. I saw that 2.8 RC1 had a fix for it, so I
>>>> grabbed the google.js from the 2.8 RC1 and tried using it with my 2.7
>>>> code.
>>>> I didn't see anything in the changes that looked like it would cause a
>>>> problem.
>>>> Here is what I ran into... I have a point vector layer with hover popups
>>>> using SelectFeature on top of google layers with sphericalMercator =
>>>> true.
>>>> When I follow the steps listed on the ticket to test the fix, the map
>>>> now
>>>> resizes correctly (thanks) but the first time I hover over a vector, the
>>>> popup is in the wrong location. So it looks like the map tiles and
>>>> vectors
>>>> are realigning after the resize, but the popups aren't.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
