[OpenLayers-Users] Overriding some default CSS values
Marc Jansen jansen at terrestris.de
Mon Aug 3 06:30:37 EDT 2009
Hi Adrian,
to change the color of the mousecoordinates div, simply override the css
like:
<style type="text/css">
.olControlMousePosition {
  color: red;
</style>
(tested)
to set the opacity of one popup you could use:
popup.setOpacity(0.7);
(tested)
If you generally want to have another opacity issue:
OpenLayers.Popup.FramedCloud.prototype.opacity = 0.1;
(untested!)
before you instantiate your popups.
Regards,
Marc
Adrian Popa schrieb:
> Hello,
> I'm trying to change the transparency of the "FramedCloud" popup in
> openlayers - to make it 90% opaque. Also, I'd like to change the font
> color for the MousePosition control. I want to make these changes as
> much as 'unintrusive' as possible - meaning I'd rather change these
> values in my code instead of the original OpenLayers code, so that I may
> upgrade openlayers in the future, without losing changes.
> Any ideas on how I can do this?
> Thanks,
> Adrian
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
