[OpenLayers-Users] Overriding some default CSS values
Adrian Popa
adrian_gh.popa at romtelecom.ro
Mon Aug 3 08:18:43 EDT 2009
Hello Marc,
Your example for the mouse coordinates worked beautifully, thanks.
However, the "setOpacity" example didn't work (the opacity attribute
didn't change in Firebug). I've tried setting popup.opacity = 0.7 - and
although I've seen the change in firebug, my popup doesn't seem to honor it.
I'm running firefox 3.0.12.
I will do further tests to see what the problem might be.
Thanks,
Adrian
Marc Jansen wrote:
> Hi Adrian,
> to change the color of the mousecoordinates div, simply override the
> css like:
> <style type="text/css">
> .olControlMousePosition {
> color: red;
> </style>
> (tested)
> to set the opacity of one popup you could use:
> popup.setOpacity(0.7);
> (tested)
> If you generally want to have another opacity issue:
> OpenLayers.Popup.FramedCloud.prototype.opacity = 0.1;
> (untested!)
> before you instantiate your popups.
> Regards,
> Marc
> Adrian Popa schrieb:
>> Hello,
>> I'm trying to change the transparency of the "FramedCloud" popup in
>> openlayers - to make it 90% opaque. Also, I'd like to change the font
>> color for the MousePosition control. I want to make these changes as
>> much as 'unintrusive' as possible - meaning I'd rather change these
>> values in my code instead of the original OpenLayers code, so that I
>> may upgrade openlayers in the future, without losing changes.
>> Any ideas on how I can do this?
>> Thanks,
>> Adrian
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
