[OpenLayers-Users] Using a more readable OpenLayers.js
Adrian Popa adrian_gh.popa at romtelecom.ro
Tue Aug 4 08:53:12 EDT 2009
Hello Marc,
My answer is inline:
Marc Jansen wrote:
> Hi Adrian,
> have you either
>    * edited the lib/OpenLayers.js file?
No, it is the original version - as far as I know
>    * or deleted / renamed ressources in any of the folders below lib?
No.
>    * Double check for "lib/OpenLayers/Layer.js"
File is there and get loaded just fine.
> Is Firebug showing any 404's in the Net(?)-tab?
No, I checked - all js get loaded.
The funny thing is - even if in Firefox with firebug this doesn't work
(also flushed the cache), in all other browsers it works - even in
firefox without Firebug. Maybe it's a firebug issue...
Thanks anyway for the help - I managed to track down the problem the
hard way...
Regards,
Adrian
> Usually this works just fine.
> Regards,
> Marc
> Adrian Popa schrieb:
>> Hello Marc,
>> I spoke too soon. If I use that file, I get ~34 errors in Firebug all
>> complaining that "OpenLayers.Layer is undefined" in various js files.
>> It seems something doesn't load properly.
>> I'm using OpenLayers 2.8, stored in /var/www/html/map/openlayers/
>> directory on my web server. My page loads it like:
>> <script type="text/javascript"
>> src="openlayers/lib/OpenLayers.js"></script>
>> Any ideas?
>> Adrian
>> Marc Jansen wrote:
>>> Hi Adrian,
>>> assuming you are using a local copy of OpenLayers, you could use
>>> OpenLayers-Folder/lib/OpenLayers.js
>>> instead of
>>> OpenLayers-Folder/OpenLayers.js
>>> which would load lots of uncompressed/non-minimized js-files.
>>> Regards,
>>> Marc
>>>> Hello,
>>>> I'm running into a problem where firebug says "element doesn't
>>>> exist" somewhere in OpenLayers code. I'm having trouble debugging
>>>> this issue, because my Openlayers code is pretty compact. What
>>>> should I include in to have OpenLayers with a more readable code?
>>>> Is there an intermediary file with formatting preserved which I
>>>> could use temporarly?
>>>> Thanks,
>>>> Adrian
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
