[OpenLayers-Users] Using a more readable OpenLayers.js
Marc Jansen
jansen at terrestris.de
Tue Aug 4 08:35:49 EDT 2009
Hi Adrian,
have you either
* edited the lib/OpenLayers.js file?
* or deleted / renamed ressources in any of the folders below lib?
* Double check for "lib/OpenLayers/Layer.js"
Is Firebug showing any 404's in the Net(?)-tab?
Usually this works just fine.
Regards,
Marc
Adrian Popa schrieb:
> Hello Marc,
> I spoke too soon. If I use that file, I get ~34 errors in Firebug all
> complaining that "OpenLayers.Layer is undefined" in various js files.
> It seems something doesn't load properly.
> I'm using OpenLayers 2.8, stored in /var/www/html/map/openlayers/
> directory on my web server. My page loads it like:
> <script type="text/javascript"
> src="openlayers/lib/OpenLayers.js"></script>
> Any ideas?
> Adrian
> Marc Jansen wrote:
>> Hi Adrian,
>> assuming you are using a local copy of OpenLayers, you could use
>> OpenLayers-Folder/lib/OpenLayers.js
>> instead of
>> OpenLayers-Folder/OpenLayers.js
>> which would load lots of uncompressed/non-minimized js-files.
>> Regards,
>> Marc
>>> Hello,
>>> I'm running into a problem where firebug says "element doesn't
>>> exist" somewhere in OpenLayers code. I'm having trouble debugging
>>> this issue, because my Openlayers code is pretty compact. What
>>> should I include in to have OpenLayers with a more readable code? Is
>>> there an intermediary file with formatting preserved which I could
>>> use temporarly?
>>> Thanks,
>>> Adrian
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
Diplom-Geograph Marc Jansen
- Anwendungsentwickler -
terrestris GmbH & Co. KG
Irmintrudisstraße 17
53111 Bonn
Tel: ++49 (0)228 / 96 28 99 -53
Fax: ++49 (0)228 / 96 28 99 -57
Email: jansen at terrestris.de
Web: http://terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin: terrestris Verwaltungsgesellschaft mbH
vertreten durch: Hinrich Paulsen, Till Adams
