[OpenLayers-Users] Scale text outside the map
Marc Jansen jansen at terrestris.de
Thu Aug 6 03:11:33 EDT 2009
Hi Hanno,
you need to pass in two parameters to the constructor of
OpenLayers.Control.Scale:
1. the div
2. the options-object
In your case this should work:
var scale = new OpenLayers.Control.Scale(
document.getElementById("kartenElemente"),
// other options
map.addControl(scale);
Regards,
Marc
Rahn Hanno (rahn) schrieb:
> Hello list,
> I have another question. Perhaps somebody can help me.
> I try to realise a Sclae text. It should be something like this
> 1:25000. For this I use the Scale Control.
> var scale = new OpenLayers.Control.Scale({
> div: document.getElementById("kartenElemente")
> I want to place the Scaletext outside the map. For this I use the div
> Option. But it doesn’t work. Can somebody please help me? Is there a
> possibility to place the control outside the map in an extra div?
> Thank you a lot for your help.
> Greetings
> Hanno Rahn
> Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
> ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und
> Natürliche Ressourcen
> Fachstelle Geoinformatik
> Grüental, Postfach CH-8820 Wädenswil
> Tel +41 (0)58 934 5592
> Fax +41 (0)58 934 5580
> hanno.rahn at zhaw.ch
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
