[OpenLayers-Users] Overlay layer jump durring pan
tommy408 tommytomorow at msn.com
Fri Aug 7 06:40:32 EDT 2009
Oh thanks a lot Ivan.  I put 2.0 ratio earlier and it fixed it.  I just
didn't understand why.
By jumping I meant the overlay layer shifts for a split second to a
different spot before adjusting to the correct spot.
Ivan Grcic-2 wrote:
> Hi, you should put ratio in untiled layer to some bigger value, at
> least 1.4 or so.
> And what excalty does it mean 'jumping' ? :)
> On Fri, Aug 7, 2009 at 12:31 AM, tommy408<tommytomorow at msn.com> wrote:
>> My overlay layer keeps jumping around when I pan the map.  It only does
>> it on
>> Firefox.  I've tried 2.6, 2.7 and 2.8.  All of them do it.  Anyone know
>> how
>> I can fix it?  It's probably somewhere in  Image.js
>>                base_layer = new OpenLayers.Layer.WMS(
>>                    "Geoserver layers - Tiled",
>> "http://localhost:8080/geoserver/wms",
>>                        height: '479',
>>                        width: '800',
>>                        layers: 'topp:custom',
>>                        styles: '',
>>                        srs: 'EPSG:4326',
>>                        format: format,
>>                        tiled: 'true',
>>                        tilesOrigin : "0,0"
>>                    {transitionEffect: 'resize'}
>>                overlay_layer = new OpenLayers.Layer.WMS(
>>                    "Geoserver layers - Untiled",
>>                        height: '479',
>>                        width: '800',
>>                        layers: 'topp:points',
>>                        styles: '',
>>                        srs: 'EPSG:4326',
>>                        format: format,
>>                        transparent: "true",
>>                        tilesOrigin : "0,0"
>>                    {singleTile: true, ratio: 1,transitionEffect:
>> 'resize'}
>>                map.addLayers([untiled,tiled]);
>> View this message in context:
>> http://n2.nabble.com/Overlay-layer-jump-durring-pan-tp3401129p3401129.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Ivan Grcic
> Users mailing list
View this message in context: http://n2.nabble.com/Overlay-layer-jump-durring-pan-tp3401129p3403584.html
