[OpenLayers-Users] Blank Postgis Mapserver layer
Suresh
vedsur at yahoo.com
Sat Aug 8 23:49:06 EDT 2009
Hi!
I am trying a simple example to draw a postgis layer using Mapserver
5.4(MS4W) and Openlayers 2.7. I am not getting the usual pink screen. When I
right click and select 'View Image', there is no mapserver error. Hence, I
am assuming that the image is drawn. However, there is no object in the
image.
I am reproducing mapfile and the HTML file below.
Mapfile
NAME "mumbai"
UNITS DD
EXTENT 72.777 18.901034910 73.046 19.308258
SIZE 640 480
IMAGECOLOR 189 202 222
IMAGETYPE PNG
# Web Object
WEB
TEMPLATE "/ms4w/apache/htdocs/vedsur/postgis.php"
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
# PostGIS layer
LAYER
CONNECTIONTYPE postgis
NAME "Roads"
CONNECTION "user=suresh password=suresh dbname=ios host=localhost"
DATA "stretch_geom from stretch"
STATUS ON
TYPE LINE
CLASS
color 255 0 255
END
END # Layer
END # Mapfile
HTML Template
var lon = 72.90;
var lat = 19.11;
var zoom = 10;
var map, layer;
function init(){
map = new OpenLayers.Map( 'map' );
var Layer = new OpenLayers.Layer.MapServer( "Circle",
"http://localhost/cgi-bin/mapserv.exe", {map:
'/ms4w/apache/htdocs/vedsur/MumbaiPG.map'}, {gutter: 15});
map.addLayer(Layer);
map.setCenter( new OpenLayers.LonLat(lon, lat), zoom);
map.addControl( new OpenLayers.Control.LayerSwitcher() );
map.addControl( new OpenLayers.Control.MousePosition() );
body onload="init()"
div id="map" class="smallmap"
/div
I have tried googling (and this forum) for two days before putting this
post. Any help is welcome.
Thanks
Suresh
View this message in context: http://n2.nabble.com/Blank-Postgis-Mapserver-layer-tp3411407p3411407.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090808/04181c7f/attachment.html
