[OpenLayers-Users] Vector file as base map
Marc Jansen
jansen at terrestris.de
Sat Aug 15 04:35:51 EDT 2009
Hi Jeremy,
simply pass in
isBaseLayer: true
as a part of the options-Object when constructing your vector layer.
Regards,
Marc
Jeremy Husmann schrieb:
> Hello everyone,
> Just a quick question.
> Im wanting to stand up a basic webpage using standard OpenLayers, but
> I want to be displaying a default KML or GML. But without any base map
> underneath – i.e. the vector file to be the base map. Is this
> possible? And if so how would you recommend starting this?
> Cheers,
> Jeremy
> *JEREMY HUSMANN***
> SOFTWARE ENGINEER
> Jeremy.Husmann at critchlow.co.nz
> *CRITCHLOW LTD***
> LEVEL 2, 22 THE TERRACE, PO BOX 4103
> WELLINGTON, NEW ZEALAND
> FREE PHONE: 0800 627 746
> DIRECT DIAL: +64 4 910 6208
> TEL: +64 4 472 8244
> FAX: +64 4 472 6695
> _ _
> *KNOW WHERE** | WWW.CRITCHLOW.CO.NZ
> <../../../../Ian/Application%20Data/Microsoft/Signatures/WWW.CRITCHLOW.CO.NZ>*
> WARNING - THIS EMAIL TRANSMISSION IS CONFIDENTIAL
> This email transmission (including any accompanying attachments)
> contains confidential information, which may be subject to legal
> privilege intended for the named addressee. If any other reader is not
> the intended recipient, you are hereby notified that any use,
> dissemination, distribution or reproduction of this email is
> prohibited. If you have received this email in error please contact us
> immediately.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
