[OpenLayers-Users] Vector file as base map
Eric Lemoine eric.lemoine at camptocamp.com
Sat Aug 15 08:59:59 EDT 2009
On Saturday, August 15, 2009, Marc Jansen <jansen at terrestris.de> wrote:
> Hi Jeremy,
> simply pass in
> isBaseLayer: true
if you have OL 2.8 you can also use allOverlays true in the map options.
Cheers,
> as a part of the options-Object when constructing your vector layer.
> Regards,
> Marc
> Jeremy Husmann schrieb:
>> Hello everyone,
>> Just a quick question.
>> Im wanting to stand up a basic webpage using standard OpenLayers, but
>> I want to be displaying a default KML or GML. But without any base map
>> underneath – i.e. the vector file to be the base map. Is this
>> possible? And if so how would you recommend starting this?
>> Cheers,
>> Jeremy
>> *JEREMY HUSMANN***
>> SOFTWARE ENGINEER
>> Jeremy.Husmann at critchlow.co.nz
>> *CRITCHLOW LTD***
>> LEVEL 2, 22 THE TERRACE, PO BOX 4103
>> WELLINGTON, NEW ZEALAND
>> FREE PHONE: 0800 627 746
>> DIRECT DIAL: +64 4 910 6208
>> TEL: +64 4 472 8244
>> FAX: +64 4 472 6695
>> _ _
>> *KNOW WHERE** | http://WWW.CRITCHLOW.CO.NZ
>> <../../../../Ian/Application%20Data/Microsoft/Signatures/http://WWW.CRITCHLOW.CO.NZ>*
>> WARNING - THIS EMAIL TRANSMISSION IS CONFIDENTIAL
>> This email transmission (including any accompanying attachments)
>> contains confidential information, which may be subject to legal
>> privilege intended for the named addressee. If any other reader is not
>> the intended recipient, you are hereby notified that any use,
>> dissemination, distribution or reproduction of this email is
>> prohibited. If you have received this email in error please contact us
>> immediately.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
