[OpenLayers-Users] Appliaction loads the first google tile and then gives up
agul abdurrahmangul at yahoo.com
Mon Aug 17 05:07:54 EDT 2009
Hi David I faced the sama problem but I couldnt solve if you find a way
please write...
David Potts wrote:
> Hi
> Am trying to load a google map via the gwt plug in and its not working.
> As far as I can tell openlayers is correctly requesting the map tiles
> from google maps(I have traced the net connection via firefox and you
> can see all the tiles being downloaded)
> When the program loads, a google map is shown in the left hand side of
> the viewport, but its cliped to about a 3rd of the viewport.
> If you scroll to the left or the right, the next tile is loaded, the
> image now takes up two thirds of the viewport.
> If you scroll to far to the right, the image drops back to left hand 1/3
> of the viewport.
> As far as I can make out I have zoomed to Extends of the map(I do this
> after the map is loaded)
> I have the projection set to EPGS:900913 ie Sperical Mercator.
> The maxResolution is set.
> I have tried the program with displayOutsideMaxExtent set to both true
> or false, it does not appear to effect the result.
> Setting a listener for a map loaded finshed loading event, never gets
> called?
> If I chage to map, a wms server everything seems to work correctly
> Whap appears to be happening,  is thats gives up after loading the first
> tile, had any body seen anything like this before?
> Dave.
> begin:vcard
> fn:David Potts
> n:Potts;David
> x-mozilla-html:FALSE
> version:2.1
> end:vcard
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/SelectFeature-control-and-click-event-on-marker-tp2186747p3457374.html
