[OpenLayers-Users] Leaving a polygon in the map which can't be
removed in the Vector Layers
Kevin Yang
yangzhaozhao2008 at 163.com
Wed Aug 19 13:59:15 EDT 2009
Hi dear sir,
When I using the draw feature function of OpenLayers, it sometimes leaves
a geometry(such as a polygon) in the map which can't be removed in the
Vector Layers, even after I close the draw control using "toggle('none')".
How can I deal with this issue?
best regards,
Yang
View this message in context: http://n2.nabble.com/Leaving-a--polygon-in-the-map-which-can%27t-be-removed-in-the-Vector-Layers-tp3474250p3474250.html
