[OpenLayers-Users] How to make a drag and drop for markers?
Alexandre Dube
adube at mapgears.com
Mon Aug 24 11:44:16 EDT 2009
Jimmy Aumard wrote:
> Thanks it's perfect for my application!!!
> I just have to develop that :s
> I have one question : It's possible to put an offset to the external
> graphic? Because images of markers (marker.png) are centered on the
> center of the image's marker and not on the bottom of the image's marker
check in lib/OpenLayers/Feature/Vector.js at the end. All properties
are there, so check the following to do what you need :
* graphicXOffset - {Number} Pixel offset along the positive x axis for
displacing an external graphic.
* graphicYOffset - {Number} Pixel offset along the positive y axis for
Never tried this, but I definitively will soon.
Best regards,
Alexandre
> I'm not sure I'm clear but it's difficult to explain this in English
> for my... Sorry
> Cheers
> Jim
> 2009/8/24 Alexandre Dube <adube at mapgears.com <mailto:adube at mapgears.com>>
> Jimmy Aumard wrote:
> Hello, thanks for answers,
> My problème is I use markers and I put/update attributes on
> each in my database. I don't know how put or update attributes
> with vector layer (if you have an example I take it :D).
> You need a server that supports transactions :
> - GeoServer
> - TinyOWS
> see the example :
> http://openlayers.org/dev/examples/wfs-protocol-transactions.html
> - FeatureServer (uses MapFish protocol)
> see a demo : http://dev4.mapgears.com/bdga-fs/
> The FS demo also shows a way to edit feature's attributes.
> I use vector layer for polygon with DragFeature. I know this
> solution but points representation is a point an I use icon,
> It's possible to put an icon to a point with a vector layer?
> Yes. Look at the following example and search the source for the
> externalGraphic property.
> http://openlayers.org/dev/examples/styles-unique.html
> Regards,
> Alexandre
> Sorry for my english :s
> Cheers
> Jim
> 2009/8/24 Eric Lemoine <eric.lemoine at camptocamp.com
> <mailto:eric.lemoine at camptocamp.com>
> <mailto:eric.lemoine at camptocamp.com>>>
> On Friday, August 21, 2009, Alexandre Dube
> <mailto:adube at mapgears.com <mailto:adube at mapgears.com>>> wrote:
> > Hi,
> > One way to accomplish this is to use a Vector layer
> instead of a
> > Marker layer and use a ModifyFeature control do move your
> points
> > (markers) around.
> The DragFeature control may be of interest as well.
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Alexandre Dubé
> Mapgears
> www.mapgears.com <http://www.mapgears.com>
Alexandre Dubé
Mapgears
www.mapgears.com
