[OpenLayers-Users] How to make a drag and drop for markers?
Jimmy Aumard
jimmy.aumard at gmail.com
Mon Aug 24 12:15:06 EDT 2009
Thanks for this informations!!
It's work correctly with:
graphicWidth: 20,
graphicHeight: 34,
graphicXOffset: -10,
graphicYOffset: -34,
externalGraphic: "../../images/marker.png"
Cheers
Jim
2009/8/24 Alexandre Dube <adube at mapgears.com>
> Hi,
> Jimmy Aumard wrote:
>> Thanks it's perfect for my application!!!
>> I just have to develop that :s
>> I have one question : It's possible to put an offset to the external
>> graphic? Because images of markers (marker.png) are centered on the center
>> of the image's marker and not on the bottom of the image's marker
> check in lib/OpenLayers/Feature/Vector.js at the end. All properties are
> there, so check the following to do what you need :
> * graphicXOffset - {Number} Pixel offset along the positive x axis for
> displacing an external graphic.
> * graphicYOffset - {Number} Pixel offset along the positive y axis for
> Never tried this, but I definitively will soon.
> Best regards,
> Alexandre
> I'm not sure I'm clear but it's difficult to explain this in English for
>> my... Sorry
>> Cheers
>> Jim
>> 2009/8/24 Alexandre Dube <adube at mapgears.com <mailto:adube at mapgears.com>>
>> Jimmy Aumard wrote:
>> Hello, thanks for answers,
>> My problème is I use markers and I put/update attributes on
>> each in my database. I don't know how put or update attributes
>> with vector layer (if you have an example I take it :D).
>> You need a server that supports transactions :
>> - GeoServer
>> - TinyOWS
>> see the example :
>> http://openlayers.org/dev/examples/wfs-protocol-transactions.html
>> - FeatureServer (uses MapFish protocol)
>> see a demo : http://dev4.mapgears.com/bdga-fs/
>> The FS demo also shows a way to edit feature's attributes.
>> I use vector layer for polygon with DragFeature. I know this
>> solution but points representation is a point an I use icon,
>> It's possible to put an icon to a point with a vector layer?
>> Yes. Look at the following example and search the source for the
>> externalGraphic property.
>> http://openlayers.org/dev/examples/styles-unique.html
>> Regards,
>> Alexandre
>> Sorry for my english :s
>> Cheers
>> Jim
>> 2009/8/24 Eric Lemoine <eric.lemoine at camptocamp.com
>> <mailto:eric.lemoine at camptocamp.com>
>> <mailto:eric.lemoine at camptocamp.com>>>
>> On Friday, August 21, 2009, Alexandre Dube
>> <mailto:adube at mapgears.com <mailto:adube at mapgears.com>>> wrote:
>> > Hi,
>> > One way to accomplish this is to use a Vector layer
>> instead of a
>> > Marker layer and use a ModifyFeature control do move your
>> points
>> > (markers) around.
>> The DragFeature control may be of interest as well.
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
>> -- Alexandre Dubé
>> Mapgears
>> www.mapgears.com <http://www.mapgears.com>
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090824/1edc95fb/attachment.html
