[OpenLayers-Users] Hover control sample (share)
Alexandre Dube
adube at mapgears.com
Thu Jan 15 17:10:08 EST 2009
Andreas Hocevar wrote:
> Hi Alexandre,
> On Thu, Jan 15, 2009 at 7:52 PM, Alexandre Dube <adube at mapgears.com> wrote:
>> Yeah, I saw your example a couple of days ago. It's a great tool. As
>> vector features are longer to draw than samples images generated by WMS
>> requests I find this quite useful.
>> The slow rendering of vector features has been one of my worries. A
>> common practice is to normalize the geometry for a given scale or have
>> different data per scale on the server side. With that in mind, I
>> wanted my vector layer to load features from different data source. See
>> the example :
>> http://dev4.mapgears.com/bdga/options-by-zoom-hover-bdga.html
>> This combine the above idea ( multiple data sources ) with the Hover
>> control. The result is quite fast. What do you think ?
> This is a good idea! But it seems there is a lot of work to do on the
> server side to prepare all the different detail levels for a WFS. Are
> you using WPS for that?
> Andreas.
Unfortunately no. Everything is hardcoded. Yeah, such a tool would be
great. Or, if it would be possible, given a specific database, to know
every possibilities at once and if the number of possibilities doesn't
go past 10, we could automatically create select boxes with the
possibles results. Else, we leave a blank textbox the user has to
fill. Plus, if only 1 possibility is available, no need to do
anything. Plus date format doesn't need to be entered either, etc
etc... ( It's good to dream ).
Do you know if something like that is possible ?
Cheers,
Alexandre
Alexandre Dubé
Mapgears
www.mapgears.com
