[OpenLayers-Users] Hover control sample (share)
Andreas Hocevar
ahocevar at opengeo.org
Thu Jan 15 16:35:35 EST 2009
Hi Alexandre,
On Thu, Jan 15, 2009 at 7:52 PM, Alexandre Dube <adube at mapgears.com> wrote:
> Yeah, I saw your example a couple of days ago. It's a great tool. As
> vector features are longer to draw than samples images generated by WMS
> requests I find this quite useful.
> The slow rendering of vector features has been one of my worries. A
> common practice is to normalize the geometry for a given scale or have
> different data per scale on the server side. With that in mind, I
> wanted my vector layer to load features from different data source. See
> the example :
> http://dev4.mapgears.com/bdga/options-by-zoom-hover-bdga.html
> This combine the above idea ( multiple data sources ) with the Hover
> control. The result is quite fast. What do you think ?
This is a good idea! But it seems there is a lot of work to do on the
server side to prepare all the different detail levels for a WFS. Are
you using WPS for that?
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
