[OpenLayers-Users] Hover control sample (share)
Alexandre Dube
adube at mapgears.com
Thu Jan 15 13:52:03 EST 2009
Yeah, I saw your example a couple of days ago. It's a great tool. As
vector features are longer to draw than samples images generated by WMS
requests I find this quite useful.
The slow rendering of vector features has been one of my worries. A
common practice is to normalize the geometry for a given scale or have
different data per scale on the server side. With that in mind, I
wanted my vector layer to load features from different data source. See
the example :
http://dev4.mapgears.com/bdga/options-by-zoom-hover-bdga.html
This combine the above idea ( multiple data sources ) with the Hover
control. The result is quite fast. What do you think ?
Alexandre
Andreas Hocevar wrote:
> Hi,
> On Thu, Jan 15, 2009 at 6:10 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>> Thanks for sharing your code Alexandre.
>> I thought about a Feature control in the past. That control would use
>> a Feature handler internally and would be configured to work either in
>> hover or click mode, just like the SelectFeature control. But, as
>> yours, it wouldn't select features, but just trigger events when
>> features are hovered or clicked. To avoid code duplication I also
>> imagined that the SelectFeature control could be based on that control
>> instead of relying directly on the Feature handler.
> just a quick note: I have chosen the same approach (a control that
> just triggers events) for the WFSGetFeature control [1]. See the
> example [2] for more details. I'll create a ticket with a patch during
> the process of getting the new WFS stuff from the topp/wfs sandbox
> into trunk.
> Regards,
> Andreas.
> [1] http://trac.openlayers.org/browser/sandbox/topp/wfs/lib/OpenLayers/Control/WFSGetFeature.js
> [2] http://dev.openlayers.org/sandbox/topp/wfs/examples/wfs-getfeature.html
Alexandre Dubé
Mapgears
www.mapgears.com
