[OpenLayers-Users] mousemove should show attributes from
database
Alexandre Dube
adube at mapgears.com
Fri Jan 16 08:33:37 EST 2009
An other example using a vector layer, information displayed in a popup
using a custom control "Hover". (click the "edit" button to see the popups):
http://dev4.mapgears.com/bdga-mapfish/
Best of luck,
Alexandre
Rahn Hanno (rahn) wrote:
> Hello list,
> I have some questions about the mousemove event and mousePosition
> control. In Openlayers it ist possible to show the coordinates of the
> mousposition in the lower right of the map for example how you can see
> in the image.
> The text will dynamically change if you are moving the mouse of
> course. I realised it like this:
> map.addControl(new OpenLayers.Control.MousePosition());
> map.events.register("mousemove", map, function(e) {
> And now my question. I want to get the name of the region if I get
> over the map. If I move the mouse over the map, the text in the lower
> right should show the name of the right region instead of the
> coordinates. The names are saved in a postgis database. I hope you
> understand what I will do, because my english ist not very well and
> somebody can help me. I tried it so long, but I didn’t find a
> solution. Perhaps somebody had already realised it and can give me
> some tipps and help. For your help a lot of thanks. I hope it will be
> possible.
> Greetings
> Hanno Rahn
> Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
> ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und
> Natürliche Ressourcen
> Fachstelle Geoinformatik
> Grüental, Postfach CH-8820 Wädenswil
> Tel +41 (0)58 934 5592
> Fax +41 (0)58 934 5580
> hanno.rahn at zhaw.ch
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
