[OpenLayers-Users] OpenLayers.ProxyHost
alyssa wright
apw217 at MIT.EDU
Mon Jan 26 16:23:38 EST 2009
hi all.
with ivan's help i made some progress. but i am still wondering if
anyone can help me fully resolve my proxyhost. i believe it's an
apache/mac thing. i've gotten an url for georss.html to run in safari,
but not firefox.
the error says: "uncaught exception: Access to restricted URI denied
(NS_ERROR_DOM_BAD_URI)" in XMLHttpRequest.js.
the xhr requests says 0.
here's a run down of what i did:
1) i saved proxy.cgi into /Library/webserver/CGI-Executables
2) then i did the chmod +x proxy.cgi
3) i was working apache through mamp, which i think was a problem. so i
uninstalled mamp and i enabled websharing in the sharing preferences pane.
4) then i did http://localhost/cgi-bin/proxy.cgi which brought me to a
local openlayers site in both firefox and safari (yay!!)
5) then i attempted to set the proxyhost variable. after a couple
different tries, i saw that setting it to: OpenLayers.ProxyHost = "";
works in safari, but not in firefox.
once figured out, i promise to write the greatest how to ever.
thanks again,
alyssa.
Ivan Grcic wrote:
> hi, try
> chmod +x proxy.cgi
> cheers
> On Fri, Jan 23, 2009 at 6:59 PM, alyssa wright <apw217 at mit.edu> wrote:
>> Hi all,
>> I know it's been asked before, but after hitting my head against many a
>> wall I humbly ask again:
>> I've been attempting to get the rss examples in general, and georss.html
>> example, in particular to work with an HTTP URL.
>> As instructed in the FAQ, I saved the proxy.cgi script from the svn
>> download in a cgi-bin folder within my local examples folder. Then I
>> set the proxyhost variable to OpenLayers.ProxyHost =
>> "/cgi-bin/proxy.cgi?url="; When I navigate to the script
>> (http://localhost:8888/openlayers/examples/cgi-bin/proxy.cgi) the
>> resulting content is the text of the script and not the openlayers
>> site. (I do not know if this is a sign of a problem).
>> When I attempt to load the feed
>> (http://www.greenwich-church.net/GeoRSS.xml) in georss.html,
>> "GeoRss.xml" shows up as an overlay, but no data registers on the map.
>> When I load this same feed on the openlayers version
>> (http://www.openlayers.org/dev/examples/georss.html) "Greenwich Church"
>> shows an an overlay along with corresponding data.
>> I have tried various combinations of where to save the proxy script
>> (e.g., in the examples folder with the georss file and the variable as
>> OpenLayers.ProxyHost = "";) and I have tried variations where the
>> AddHandler section of my httpd.conf knows to call python (as instructed
>> here http://gist.fas.harvard.edu/chgis/?p=14).
>> Any help is greatly appreciated.
>> Best,
>> Alyssa.
>> PS. I am not that interested in greenwich churches. . . it was just an
>> easy test case.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090126/cac7bd3b/attachment.html
