[OpenLayers-Users] Ancored Popup Autosize troubles
小粟 weimin_su at 126.com
Wed Jan 28 02:25:29 EST 2009
I just checked the content size and set the popup size dynamicly.
Regards,
suen
----- Original Message -----
To: <users at openlayers.org>
Sent: Tuesday, January 27, 2009 9:40 AM
Subject: [OpenLayers-Users] Ancored Popup Autosize troubles
> Hello list.  I have my map just about where I need it but the anchored popups
> are giving me a hard time.  I have tried to include the autosize command
> with little luck.  Any thoughts?
> Regards-WS
> <html xmlns="http://www.w3.org/1999/xhtml">
>  <head>
>    <title>World Map</title>
>    <style type="text/css">
>        #map {
>            width: 1000px;
>            height: 600px;
>            border: 1px solid black;
>    </style>
>    <script
> src='http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ'></script>
>    <script type="text/javascript"
> src="http://openlayers.org/api/OpenLayers.js"></script>
>    <script type="text/javascript" src="data/world_borders.js"></script>
>    <script type="text/javascript">
>        var map;
>        var popup;
>        function init(){
>            var options = {
>                projection: new OpenLayers.Projection("EPSG:900913"),
>                displayProjection: new OpenLayers.Projection("EPSG:4326"),
>                units: "m",
>                maxResolution: 156543.0339,
>                numZoomLevels: 10,
>                maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
>                                                 20037508.34, 20037508.34)
>            map = new OpenLayers.Map('map',options);
>            var gmap = new OpenLayers.Layer.Google("Google Streets",
>                'sphericalMercator': true
>            map.addLayer(gmap);
>            var colors =
> ["#7d0000","#be0b00","#e65100","#ff9700","#fcc900"];
>            var ranges = [15,30,45,60,75];
>            var context = {
>                getColor: function(feature) {
>                    for (var i = 0; i < ranges.length; i++){
>                       if (feature.attributes.Act_T <= ranges[i]){
>                           return colors[i];
>                           //return "#99000d";
>            var template = {
>                fillColor: "${getColor}", // using context.getColor(feature)
>                fillOpacity: ".75",
>                strokeColor:"black",
>                strokeWidth:1
>            var style = new OpenLayers.Style(template, {context: context});
>            var styleMap = new OpenLayers.StyleMap({'default': style,
> select: {fillColor: "333333"}, hover: {fillColor: "333333"}});
>            var geoJSON = new OpenLayers.Format.GeoJSON();
>            var world_borders = new OpenLayers.Layer.Vector("Open Source
> Activity",{styleMap:styleMap, isBaseLayer: false,
>            projection: new OpenLayers.Projection("EPSG:4326"),
>            attribution: " www.zzzzz.com zzzz "});
>            world_borders.addFeatures(geoJSON.read(features));
>            map.addLayer(world_borders);
>            var select = new
> OpenLayers.Control.SelectFeature(world_borders,{hover:true,clickFeature:createPopup,onUnselect:unSelect});
>            map.addControl(select);
>            select.activate();
>            map.addControl(new OpenLayers.Control.MousePosition());
>            var center = new OpenLayers.LonLat(0,30);
> center.transform(map.displayProjection,map.getProjectionObject());
>            map.setCenter(center, 2);
>        function createPopup(feature){
>            if (popup != null) {
>                map.removePopup(popup);
>                popup.destroy();
>                popup = null;
>            feature.lonlat = feature.geometry.getBounds().getCenterLonLat();
>            if (popup == null) {
>                popup = new OpenLayers.Popup.Anchored ("popup",
> feature.lonlat, new OpenLayers.Size(200,200),
> null, null, null,
>                           function () {
>                               map.removePopup( popup ); popup.destroy();
> popup = null;
>                var content = "<div>"+ feature.attributes.CNTRY_NAME +
> "</div><br>" +
>                    "<div><table>" +
>                    "<tr><th align='right'>Overall Rank:</th><td> " +
> feature.attributes.Act_T + "</td></tr>" +
>                    "<tr><th align='right'>Government Rank:</th><td> " +
> feature.attributes.Act_G + "</td></tr>" +
>                    "<tr><th align='right'>Industry Rank:</th><td>" +
> feature.attributes.Act_I + "</td></tr>" +
>                    "<tr><th align='right'>Community Rank:</th><td> " +
> feature.attributes.Act_C + " </td></tr>" +
>                    "</table></div>";
>                popup.setContentHTML(content);
>                popup.setBackgroundColor("white");
>                popup.setOpacity(1);
>                popup.events.register('mousemove', popup, function (e)
> {try{e.stopPropagation();}catch(e){}});
>                map.addPopup(popup);
>          } else {
>                popup.destroy();
>                popup = null;
>       function unSelect(){
>                popup.destroy();
>                popup = null;
>    </script>
>  </head>
>  <body onload="init()">
>    <center>
>      <div id="map"></div>
>    </center>
>  </body>
> </html>
> any thoughts on disabling the scroll wheel would be great too!
> Thanks
> View this message in context: http://n2.nabble.com/Ancored-Popup-Autosize-troubles-tp2221855p2221855.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
