[OpenLayers-Users] Ancored Popup Autosize troubles
smithfield
willsmithfield at gmail.com
Wed Jan 28 10:12:37 EST 2009
Unfortunately, that didn't really answer the question. Could you be more
specific?
Thanks.
小粟 wrote:
> I just checked the content size and set the popup size dynamicly.
> Regards,
> suen
> ----- Original Message -----
> From: "smithfield" <willsmithfield at gmail.com>
> To: <users at openlayers.org>
> Sent: Tuesday, January 27, 2009 9:40 AM
> Subject: [OpenLayers-Users] Ancored Popup Autosize troubles
>> Hello list. I have my map just about where I need it but the anchored
>> popups
>> are giving me a hard time. I have tried to include the autosize command
>> with little luck. Any thoughts?
>> Regards-WS
>> <html xmlns="http://www.w3.org/1999/xhtml">
>> <head>
>> <title>World Map</title>
>> <style type="text/css">
>> #map {
>> width: 1000px;
>> height: 600px;
>> border: 1px solid black;
>> </style>
>> <script
>> src='http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ'></script>
>> <script type="text/javascript"
>> src="http://openlayers.org/api/OpenLayers.js"></script>
>> <script type="text/javascript" src="data/world_borders.js"></script>
>> <script type="text/javascript">
>> var map;
>> var popup;
>> function init(){
>> var options = {
>> projection: new OpenLayers.Projection("EPSG:900913"),
>> displayProjection: new OpenLayers.Projection("EPSG:4326"),
>> units: "m",
>> maxResolution: 156543.0339,
>> numZoomLevels: 10,
>> maxExtent: new OpenLayers.Bounds(-20037508.34,
>> -20037508.34,
>> 20037508.34, 20037508.34)
>> map = new OpenLayers.Map('map',options);
>> var gmap = new OpenLayers.Layer.Google("Google Streets",
>> 'sphericalMercator': true
>> map.addLayer(gmap);
>> var colors =
>> ["#7d0000","#be0b00","#e65100","#ff9700","#fcc900"];
>> var ranges = [15,30,45,60,75];
>> var context = {
>> getColor: function(feature) {
>> for (var i = 0; i < ranges.length; i++){
>> if (feature.attributes.Act_T <= ranges[i]){
>> return colors[i];
>> //return "#99000d";
>> var template = {
>> fillColor: "${getColor}", // using
>> context.getColor(feature)
>> fillOpacity: ".75",
>> strokeColor:"black",
>> strokeWidth:1
>> var style = new OpenLayers.Style(template, {context:
>> context});
>> var styleMap = new OpenLayers.StyleMap({'default': style,
>> select: {fillColor: "333333"}, hover: {fillColor: "333333"}});
>> var geoJSON = new OpenLayers.Format.GeoJSON();
>> var world_borders = new OpenLayers.Layer.Vector("Open Source
>> Activity",{styleMap:styleMap, isBaseLayer: false,
>> projection: new OpenLayers.Projection("EPSG:4326"),
>> attribution: " www.zzzzz.com zzzz "});
>> world_borders.addFeatures(geoJSON.read(features));
>> map.addLayer(world_borders);
>> var select = new
>> OpenLayers.Control.SelectFeature(world_borders,{hover:true,clickFeature:createPopup,onUnselect:unSelect});
>> map.addControl(select);
>> select.activate();
>> map.addControl(new OpenLayers.Control.MousePosition());
>> var center = new OpenLayers.LonLat(0,30);
>> center.transform(map.displayProjection,map.getProjectionObject());
>> map.setCenter(center, 2);
>> function createPopup(feature){
>> if (popup != null) {
>> map.removePopup(popup);
>> popup.destroy();
>> popup = null;
>> feature.lonlat =
>> feature.geometry.getBounds().getCenterLonLat();
>> if (popup == null) {
>> popup = new OpenLayers.Popup.Anchored ("popup",
>> feature.lonlat, new OpenLayers.Size(200,200),
>> null, null, null,
>> function () {
>> map.removePopup( popup ); popup.destroy();
>> popup = null;
>> var content = "<div>"+ feature.attributes.CNTRY_NAME +
>> "</div><br>" +
>> "<div><table>" +
>> "<tr><th align='right'>Overall Rank:</th><td> " +
>> feature.attributes.Act_T + "</td></tr>" +
>> "<tr><th align='right'>Government Rank:</th><td> " +
>> feature.attributes.Act_G + "</td></tr>" +
>> "<tr><th align='right'>Industry Rank:</th><td>" +
>> feature.attributes.Act_I + "</td></tr>" +
>> "<tr><th align='right'>Community Rank:</th><td> " +
>> feature.attributes.Act_C + " </td></tr>" +
>> "</table></div>";
>> popup.setContentHTML(content);
>> popup.setBackgroundColor("white");
>> popup.setOpacity(1);
>> popup.events.register('mousemove', popup, function (e)
>> {try{e.stopPropagation();}catch(e){}});
>> map.addPopup(popup);
>> } else {
>> popup.destroy();
>> popup = null;
>> function unSelect(){
>> popup.destroy();
>> popup = null;
>> </script>
>> </head>
>> <body onload="init()">
>> <center>
>> <div id="map"></div>
>> </center>
>> </body>
>> </html>
>> any thoughts on disabling the scroll wheel would be great too!
>> Thanks
>> View this message in context:
>> http://n2.nabble.com/Ancored-Popup-Autosize-troubles-tp2221855p2221855.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://n2.nabble.com/Ancored-Popup-Autosize-troubles-tp2221855p2232720.html
