[OpenLayers-Users] Projection object, use and documentation.
Christopher Schmidt
crschmidt at metacarta.com
Fri Jan 30 07:02:19 EST 2009
On Fri, Jan 30, 2009 at 10:19:48AM -0000, David Potts wrote:
> Hi List
> I have having some problems with the Projection object, I am trying to
> use it set up a layer ojbect on a google map layer.
David,
By default, you may not need to use anything to accomplish this goal.
Can you explain what you mean more by a 'layer object'? (Rasters,
vectors, etc.)
> The projection object OpenLayers. Projection includes functions to return
> the SRS code units string for maps and takes an optional object with
> properties to set on the format.
The latter was a mistake in the documentation, now fixed:
http://dev.openlayers.org/apidocs/files/OpenLayers/Projection-js.html#OpenLayers.Projection.OpenLayers.Projection
> I have seen the projection object set up via just quoting a SRS string, is
> this the valid
Valid and expected.
Have you read http://docs.openlayers.org/library/spherical_mercator ?
Regards,
Christopher Schmidt
MetaCarta
