[OpenLayers-Users] Can't get OpenLayers to Co-operate with
TileCache resolutions
soatley
shawn at niagarafalls.ca
Thu Jul 2 22:29:11 EDT 2009
Getting closer yet....
I figured out that it has to do with the metaSize parameter. I tried
setting it to the default (5,5) and the problems were corrected. I am able
to get it up to 8,8 without a problem. Once I hit 9,9 or above, I start
getting oddities - the higher I go, the more I get. Wierd.....
One thing I am not noticing is that OpenLayers is requesting tiles that are
way outside my bounds. For example, on my Zoom level 0, it is asking for:
/tilecache/basewdrawing/00/000/000/028/000/000/024.png
This is way out because my zoom level 0 is only 1 tile (256X256) and the
entire map takes up about 1/10th of the tile.
Has anyone else had this happen to them? The client doesn't get any error
messages, but there are a ton of 404's happening in the background along
with the increased traffic from the browser to the server attempting to get
all these crazy tiles.
Shawn
soatley wrote:
> With a little more fooling around, I have found that it has to do with the
> MetaTiling....
> My WMS Server is Manifold 8.0 and it can only write out PNG images. I am
> using .NET to write out the binary stream to TileCache from Manifold. I
> don't think it is an Interlacing issue because TC would complain if I sent
> it an interlaced PNG.
> [snip...]
View this message in context: http://n2.nabble.com/Can%27t-get-OpenLayers-to-Co-operate-with-TileCache-resolutions-tp3198651p3199157.html
