[OpenLayers-Users] URL too long for IE mergeNewParams &
MapServer replacement variable
karsten vennemann
karsten at terragis.net
Tue Jul 7 10:57:57 EDT 2009
I will look into using SLD , looks like something really worth learning
about.
Thanks for the hint.
Karsten
> -----Original Message-----
> From: andreas.hocevar at gmail.com
> [mailto:andreas.hocevar at gmail.com] On Behalf Of Andreas Hocevar
> Sent: Monday, July 06, 2009 00:30
> To: karsten vennemann
> Cc: users at openlayers.org
> Subject: Re: [OpenLayers-Users] URL too long for IE
> mergeNewParams & MapServer replacement variable
> Hi,
> POST is not possible, because map tiles are loaded into
> <img/> elements. What you could do, however, is use CQL
> filters instead of SQL strings. These are usually shorter.
> Not sure if Mapserver supports these though.
> Another thing you could do is use OGC filters and build an
> SLD dynamically. If you use PHP already, you will also have a
> session scope. You can post the SLD, and when you get the
> response from the server refresh your layer, which would
> access the sld associated with the user session. You can do
> this by setting an SLD param on the layer in OpenLayers, just
> pointing to a url (e.g.
> http://localhost/mysld.php?PHP_SID=mysessionid).
> Regards,
> Andreas.
> On Fri, Jul 3, 2009 at 8:28 PM, karsten
> vennemann<karsten at terragis.net> wrote:
> > I have set-up a a dynamic layer with Mapserver and
> OpenLayers based
> > on a user defined query of data.
> > In my Mapserver file I have defined a PostGIS layer with a
> replacement
> > variable. The user fills in values in a query builder html
> form, the
> > resulting SQL string is sent via POST to a PHP page containing the
> > OpenLayers map. Using mergeNewParams the SQL string is
> merged into the
> > the request for the layer, MapServer handles the
> > and the dynamic layers is displayed correctly. So far this works
> > great in Firefox but for the most complicated queries coming out of
> > the query builder the SQL string is becoming very long and
> the request
> > by Openlayers to display the layer will exceed 2048 characters (the
> > apparent limit for IE 7) - thus breaking the application...
> > Here is my question how can I set this up so that it is
> still working
> > also in IE (preferably without changing the data base
> column names and
> > without using MapScript).
> > Is there a way that I can use POST instead of GET to
> transmit the SQL
> > string to MapServer somehow. Any other ideas how I can get
> this done ?
> > Karsten Vennemann
> > Seattle, USA
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
