[OpenLayers-Users] Visibility of features in vector layer
Andreas Hocevar ahocevar at opengeo.org
Wed Jul 8 12:41:43 EDT 2009
Paul Spencer wrote:
> Eric,
> On 8-Jul-09, at 9:25 AM, Eric Lemoine wrote:
>> On Wednesday, July 8, 2009, Matthew Doyle <M.Doyle at bom.gov.au> wrote:
>>> Hello all,
>>> Sorry for resurrecting this topic, but i am having trouble getting my
>>> features to "remember" which StylemMap they have been changed to,
>>> using the
>>> renderIntent.
>>> After following Heidtmare's suggestions below, my WFS layer is now
>>> showing
>>> and hiding features on the fly using the renderIntent and then
>>> calling
>>> drawFeature, as follows:
>>> for(var i = 0; i < WFSLayer.features.length; i++) {
>>>   WFSLayer.features[i].renderIntent = "hidden";
>>>   WFSLayer.drawFeature(WFSLayer.features[i]);
>>> This works great, right up until i zoom the map or move to a
>>> different
>>> extent. Each feature goes back to their "default" renderIntent and
>>> the
>>> features are shown once again.
>>> How can i force a permanent change for each feature so that when
>>> the user
>>> zooms it remembers what changes have just been made?
>> Hi
>> You can use the "style" property. E.g.
>> feature.style = OpenLayers.Feature.Vector.style["delete"];
> why does the renderIntent approach not work?  It does work for
> controls like SelectFeature.  From what I see in the code, the
> renderIntent of the feature is changed in createSymbolizer called from
> drawFeature, which should use the renderIntent of the feature (in this
> case, 'hidden').  Unless the style map doesn't contain a 'hidden'
> style, in which case it would default back to ... um ... 'default' :)
Absolutely right. Matthew, if you don't have a "hidden" intent, features won't be rendered with it. Maybe you meant "delete", because that is the renderIntent for hiding features.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
